10-16-2012, 12:44 AM | #1 |
Stuck Front Driveshaft
I am in the process of installing a 4inch Tuff Country Lift.
My front driveshaft slip joint is stuck. I managed to get it to extend a few inches with a ratchet strap and a sledge hammer and I can now finish putting the new springs on. The question is, Should I remove the shaft and try to free it up, or should I just grease the hell out of it and run it as-is? |
10-16-2012, 12:56 AM | #2 |
Re: Stuck Front Driveshaft
Take it off, clean it with solvent, unscrew the cap that holds the seal, pull it apart, wire brush it or what ever it takes, grease it and put it back on
Its not that much work. If your burnt out from doing the spring install, take a break and clean it up and put it on a few days later or whatever Good time to check your u joints too
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
10-16-2012, 01:06 AM | #3 | |
10-16-2012, 01:36 AM | #4 |
That cap there where the shaft slides in unscrews, gotta unscrew the cap so the slip shaft can slide all the way out,. I could unscrew it with my hand rapped around it. Might need a pipe wrench with a rag rapped around it so you dont mark it up to bad I gotta replace my front pinion seal so I have to take my front shaft off too so I can clean and paint it, if I can get my butt in gear tomarrow. My splines are kinda loose and probably need a new slip yoke welded on eventually
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting Last edited by GSP7; 10-16-2012 at 01:57 AM. |
10-16-2012, 07:54 AM | #5 |
Some of them unscrew, and some pop off like the one in the picture above. The ones that pop off are a pain to get on and off. I made a tool out of a piece of oak that slips behind the seal/cap. Sort of a U cut into the end of the piece of wood. That way i can hammer on the wood to pop the seal/cap off.
I wouldn't use a drive shaft that dosent slide nice.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
10-16-2012, 09:50 AM | #6 |
This one has little taps that fold.
10-16-2012, 10:21 AM | #7 |
10-16-2012, 10:48 AM | #8 |
Here ya go, you can buy a new cap and seal which ever type you need
scroll down to the caps. you can measure what you have and get the right on http://www.dennysdriveshaft.com/c461...iveshafts.html Mine is larger diameter than the above pic then tapers down and the serk is in the center instead of at one end I see Dennys has some good spicer U joints too at a good price. I just bought a Fed/mogul precission U Joint for my rear. I should have ordered a spicer. /
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting Last edited by GSP7; 10-16-2012 at 11:00 AM. |
10-16-2012, 12:56 PM | #9 | |
