Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 10-16-2012, 10:35 AM   #1
darush01
2000 jimmy ignition help
I have a problem with my 2000 jimmy i thought it was fuel related but ive had 2 shops say its ignition one said it was the ognition switch i had them replace it and it did nothing, now another guy says its the ignition switch module but wants almost $300 to fix it, where is the module and how hard is it to change? If i can do it and save as much as possible id like to because im on a tight budget any help appreciated
darush01 is offline   Reply With Quote
Old 10-16-2012, 11:04 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 2000 jimmy ignition help
OUCH! The part only costs a few bucks. It's located above the left side valve cover. It's bolted to the coil. Disconnect the distributor wire and harness. Unbolt the bracket hold coil and ignition module. Seperate them, and replace the module. 20 minute job!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 10-16-2012, 11:05 AM   #3
gchemist
gchemist's Avatar
You can see the coil in this picture left of the TB.
http://rides.webshots.com/photo/2159...54440533EbnVjD
Old 10-16-2012, 03:38 PM   #4
darush01
That is the ignition control module right? I finally got to talk to the guy who wants to charge me 300 for a 20 min job and he sounded sure that that was my problem so im gonna try it thanks for the info
Old 10-16-2012, 03:41 PM   #5
darush01
Oh and sorry for sounding ignorant i can rebuild my 72 from the ground up but this computer controlled stuff is annoying
Old 10-16-2012, 11:22 PM   #6
gmachinz
I'm coming from a different angle on this one-are you getting good oil pressure while cranking? If the ECM does not see enough oil pressure while cranking, it will not kick the fuel pump relay on or fire the drivers for the injectors. If the ign module doesn't change anything, try changing the oil pressure switch/sensor and/or inspect the wiring for it.
gmachinz is offline   Reply With Quote
Old 10-17-2012, 12:00 AM   #7
darush01
If it doesnt fix it ill look at that thanks for the idea
Old 10-17-2012, 10:22 AM   #8
gchemist
gchemist's Avatar
Did the mechanic mention it does not have spark? If so then, yes the ignition module has failed.
Quick test. Pour a little fuel down the TB. Crank it. If it runs for a few seconds, spark is good, fuel delivery is bad.
Old 10-17-2012, 01:25 PM   #9
darush01
Right not i cant check anything until i pick it up from the shop
Old 10-17-2012, 06:36 PM   #10
GMCJOE
GMCJOE's Avatar
Give us the fault so we can better diagnos the problem for you. Or give you tips on what to check.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 10-18-2012, 10:27 PM   #11
darush01
Im not sure what it pulled up i had the codes ran a few months ago when it first acted up and i got some sort of emissions and abs codes i cleared those and idont know what the mechanic pulled up
Old 10-20-2012, 10:12 AM   #12
dyrt
i recommend checking out s10forums for problems with your model and year. I have a 2000 gmc jimmy 2dr 2wd 5 speed and let's just say that these vehicles have some pretty common problems. Almost all of my searches end up in those forums reading problem descriptions exactly like those i was about to write. Like said above, spray some fuel down and see if it ignites to test if ignition is working or not.
dyrt is offline   Reply With Quote
Old 10-20-2012, 10:15 AM   #13
GMCJOE
GMCJOE's Avatar
So, what is the problems that you are having with it? Does it start and run? What are the issues. Then I may be able to give you a little help on figuring the issue out.
Joseph
Joe's 69 GMC
