Old 10-16-2012, 01:02 PM   #1
jeromio
Remove instrument panel??
I am stumped. Took out all screws and all knobs and ignition switch. Something is keeping this thing from budging. What am I missing? How do I remove the gauge panel?
jeromio is offline   Reply With Quote
Old 10-16-2012, 01:05 PM   #2
1963c-10
1963c-10's Avatar
Re: Remove instrument panel??
Disconnect the speedometer cable from the back and the cluster should slide forward. Disconnect the cluster harness and it should be free.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-16-2012, 01:46 PM   #3
DoubleL
DoubleL's Avatar
I just took mine out, reinstalled, then out again, then reinstalled. Pull it as far forward as possible and look under the lip of the cluster bezel on the bottom. You may be getting hung up on the dash metal inset that the wiper and headlight switch fit into. You may need to gently pry up to get it to clear. You will be able to pull it out just far enough to disconnect the speedo cable, then unplug the harness. Mine was a pain. Don't get to rough with it but show it who's boss!
DoubleL is offline   Reply With Quote
Old 10-16-2012, 04:37 PM   #4
brokenspoke
brokenspoke's Avatar
Dont forget the oil line if you have one
brokenspoke is offline   Reply With Quote
Old 10-16-2012, 06:36 PM   #5
jdl71
jdl71's Avatar
I had the same problem. Ended up taking out the heater controls so I could get my hand in behind there better to push.
jdl71 is offline   Reply With Quote
Old 10-16-2012, 08:03 PM   #6
awbrown
mine had some tabs sticking up off the dash sheetmetal , it made it come out some dry ... do a little pryng and look real close with a flashlight..
awbrown is offline   Reply With Quote
