Old 10-16-2012, 05:13 PM   #1
cmyc5575
Breaking issues plz help this is my D/D!!!!
Ok I bought this truck back in May as a bday present to myself and there was already an issue with the ds caliper engaging late and causing the truck to pull to the left. So no big deal I would just replace the caliper and that should fix the problem. I havent gotten around to doing that yet, but my issues that I am havnig now has gotten worse. When I am driving the truck and hit the brake to slow down the brakes work just fine but, when I start taking off again I can feel the front brakes are still grabbing and will not release until I hit the brake a few more times. This in turn is causing the truck to bounce and skip when I'm driving. Any advice or suggestions to what I need to do is much appreciated.
cmyc5575 is offline   Reply With Quote
Old 10-16-2012, 05:36 PM   #2
RastaRobb
RastaRobb's Avatar
Re: Breaking issues plz help this is my D/D!!!!
Yup, it's doing more than just "making the truck bounce and skip" it is burning up the rotors as well. Sounds like the piston is not retracting properly. Get that caliper changed out quick, and you make stronly consider doing the other side as well. Check the rotors as well. If they are warped or grooved you need to be replacing them too. Call it an early Christmas present to yourselft.
RastaRobb is offline   Reply With Quote
Old 10-16-2012, 05:40 PM   #3
cmyc5575
Yeah I figured that it was causing the rotors to get hot becuase you can smell that "burnt" smell when its happening and its also causing me to have to push the gas down alil more than normal to get the truck to take off. Is there any other Issues that could possibly cause this to happen? I just want to make sure that I have every base covered so I dont give someone in front of me a new rear end lift.
Old 10-16-2012, 05:41 PM   #4
Hevy
Hevy's Avatar
Don't wait so long if you have brake issues... May to October is too long.
I'd change both calipers and pads, check the rotors.
Hevy is offline   Reply With Quote
Old 10-16-2012, 06:00 PM   #5
cmyc5575
I plan on addressing it this weekend.
Old 10-16-2012, 06:55 PM   #6
meter swinger
meter swinger's Avatar
I would just do the whole mess. I used to get rotors turned and try and save the calipers. Now on the front I replace all of it. Its not that expensive anyway. Look at the cost of calipers, rotors, pads, hoses as cheaper than an accident.
meter swinger is offline   Reply With Quote
Old 10-16-2012, 07:10 PM   #7
cmyc5575
I totally agree. lol I just called auto zone oreillys and advanced auto parts and all of them want these codes to make sure that i buy the correct parts. One wanted me to measure the back drum brakes just to get the size for the front rotors. Im about to pull my hair out, and I cant tear into them until this weekend.
Old 10-16-2012, 07:13 PM   #8
clinebarger
Front brake hoses!!!!!!!
clinebarger is offline   Reply With Quote
Old 10-16-2012, 07:32 PM   #9
legendman
legendman's Avatar
^^^ Ditto could be caliper hoses collapsing, I would replace those too.
What year is the truck? 2wd or 4wd?
1/2 or 3/4 ton.
If it's 2wd 1/2 ton then only choices should 1 inch or 1 1/4 inch rotors.
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 10-16-2012, 08:02 PM   #10
clinebarger
Should be a RPO list in the glove compartment. JB3, JB5, JB6, & JB7 should be the choices, You should be able to order any brake part you need with this code.
Old 10-16-2012, 08:38 PM   #11
kenbob87
kenbob87's Avatar
ive also seen it happen a time or two when brakes are sticking and people keep driving them they heat up the grease in the bearing to the point that it leaks out which in turn takes out the wheel bearings
kenbob87 is offline   Reply With Quote
Old 10-16-2012, 08:52 PM   #12
rwhit57
rwhit57's Avatar
99% of the time this is the problem.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 10-16-2012, 09:49 PM   #13
cmyc5575
How much am I going to have to pay for some of these.
Legendman: its a 1982 gmc high sierra 2wf
Clinebarger: i didnt have any "jb" codes the only one that I have is that one says "J50 power brake system".
Old 10-16-2012, 10:04 PM   #14
legendman
legendman's Avatar
?? 2wf? Do you mean 2wd? 1/2 or 3/4 ton?
If it's a half ton then they only came with 2 different brake systems
1 inch or 1 and 1/4 rotors should be all you need to know to get the front calipers, pads, rotors and hoses.
Old 10-16-2012, 10:22 PM   #15
cmyc5575
Oooops lol Yes 2wd its a 1500. But what about the rpo? Clinebarger stated jb something another when all I see is j50?
Old 10-16-2012, 10:56 PM   #16
meter swinger
Classic parts has front hoses for about 20$ per side. You may find them cheaper locally. Like everyone says they are prone to collapse. I would do it all ( pads discs calipers hoses) since the truck is new to you and the overall condition is unknown. Then you would know what ya got
Old 10-16-2012, 11:33 PM   #17
cmyc5575
Yeah I just had one of the a/p coworkers here look at them for me and stated that I should try this to. Along with buying new ball joints because they looker worn out.
Old 10-17-2012, 12:34 AM   #18
hatzie
Moderator
hatzie's Avatar
I usually get loaded calipers, rotors, and hoses online from RockAuto Loaded calipers come with pads and hardware usually including guide pins. You can get the real cheap stuff... But... Raybestos or Wagner loaded should be around $40-$60 a caliper with the core charge. Good rotors are pretty cheap and quality name-brand hoses are usually right around $10.
I usually flush the whole system, with fresh fluid from an unopened bottle, till it runs clean out the front and back bleeders. It cuts down on the water and internal rust.
TRW and Moog used to be good names in ball joints. IDK anymore. I think they're all made in Asia or India now.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 10-17-2012, 12:38 AM   #19
cmyc5575
Yeah I was thinking going with Moog but havent quite started doing any price comparing just yet. Im more worried about my brakes. lol
Old 10-17-2012, 07:19 AM   #20
Keith Seymore
Keith Seymore's Avatar
Here's the brake system release chart for an '87, for reference:
One of the things you could do is look for a code on the brake vacuum booster, which would help distinguish which brake system (JB3 = "CH" vs JB5 = "FD") that you have.
Bottom line, though, is we build very very few JB3s. If you simply guessed JB5 you would likely be right.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-17-2012, 07:56 AM   #21
lolife99
67-72 parts collector,…
lolife99's Avatar
front brake hoses!!!!!!!
Yes!
If it's pulling to the left,... the right hose is collapsed.
Change them both.
Keith
Convert to disc brakes.
Old 10-17-2012, 04:57 PM   #22
cmyc5575
Yes!
Change them both.
I got underneath and squeezed both the lines and they both seem fine i believe that the caliper itself is bad. my rpo says j50 would that be the same as jb5?
Old 10-17-2012, 05:18 PM   #23
JCampbell
Good God! Park the damn truck until you fix it before you kill someone.
JCampbell is offline   Reply With Quote
Old 10-17-2012, 05:35 PM   #24
cmyc5575
Wow man wtf is your problem? Im asking questions about my breaks. For all you know the truck is parked.
Old 10-17-2012, 05:44 PM   #25
Zebb
Zebb's Avatar
That won't tell you if it is good or not.
It will only take a few minutes more to change the hoses. You won't be happy if you still have the same problem after you have cheaped out on $20.00 worth of hoses. When hoses fail it is usually the inner part that you cannot see. Brake pressure pushes the fluid into the caliper then it can't return because the inner part of the hose is collapsed. A good mechanic would change it along with a caliper just to ensure the vehicle is fixed right and won't come back or worse hurt somebody.
Zebb is offline   Reply With Quote
