10-16-2012, 09:03 PM | #1 |
show me your v8 mods
hi all
gonna stick a v8 in my 49 AD 1 1/2 ton. wanna see pictures of mods that had to be done to make the fit and mods to make steering wheel work. ive looked through the build threads and not a whole lot of ADs compared to you TF guys and as always thanks for the input in advance |
10-17-2012, 12:19 AM | #2 |
Re: show me your v8 mods
It's a tight fit, but can be done.
I used this cross member from classic parts, http://www.classicparts.com/1947-59-.../#.UH4wwq7AtTg I had to offset the engine a little, and I'm using 305 manifolds on mine. |
10-17-2012, 10:18 AM | #3 |
Hell it isnt that tight. I have a pontiac 400 in mine{wider and longerthat the SBC}. and there are lots of big block chevys around.
Just get the engine as far back as you can. Useing the frame you have you wont have the usual problem of the ad framed trucks. |
10-17-2012, 11:18 AM | #4 |
thanks for the input guys. if im using my 1 1/2 ton frame and cut off the original drop axle and a different axle under with different leaf springs. what do i need to use for engine mounts. im sure ill be cutting out the tranny support thats in my 78 donor parts truck. but can i use the engine mounts from it or do i need to make or buy different
10-17-2012, 12:48 PM | #5 | |
Do you have any pics? Are you using the stock steering box? |
10-17-2012, 05:48 PM | #6 |
1950 3600 bbc.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
10-17-2012, 06:08 PM | #7 |
10-17-2012, 06:46 PM | #8 |
10-17-2012, 07:07 PM | #9 |
thanks, 1985 c10 and i did not narrow it, i made 2 1/4" plates and slid 1 down each side.
10-17-2012, 07:43 PM | #10 | |
I guess you also spaced out the steering box? how is the track width? I have heard its too wide but I have steelies on my truck right now and there is a ton of space between them and the fenders. I have a free 83,4,or 5 C10 coming my way and I am going to be putting the suspension on my 50 so I have alot of questions. Thanks for any help, chris |
10-17-2012, 08:45 PM | #11 |
what is the best Quadjet carb for fuel mileage thats going on my v8
10-17-2012, 09:35 PM | #12 |
Crossfire84: Nice lookin' engine. I am kinda' partial to Big Blocks. Good luck with your build.
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
10-18-2012, 05:28 PM | #13 | |
10-18-2012, 09:24 PM | #14 |
Midgets50, Take a look at my build thread, we did a 52 with a big block. I am not quite finished yet but I have some progress pictures. We used the March front drive setup and that made it pretty tight, I think if we had gone with more of a stock pulley drive setup it might have fit better. I had to reposition the motor a couple of times because of changes but I got it. I can't remember where we got the mounts but the were a universal mount that I welded to the front boxing plates. Good luck and if you have any questions let me know.
Bernie |
10-18-2012, 11:02 PM | #15 |
wow thats a great build thread. youve done alot of work to that truck
