Old 10-16-2012, 10:11 PM   #1
superwade57
VIN help
i have a 78 thats pretty much junk. except the axles are supposed to be dana 60 and corporate 14 with 5.xx:1 gears... this is what im told. it is impossible to get under the truck to verify numbers, i would have to dig the truck out from its grave as its very very overgrown into place as its been in its place for 20 years.
is there a way to know what the gears are based on vin or spid if its not specified? heres the info i have
VIN CKR248J149958
SPID
MODEL: CK20903
A28 SLIDING REAR WINDOW
E63 FLEETSIDE BED
G80 LOCKING DIF.
K76 61 AMP DELCOTRON GE
MX1 AUTO TRANS
NL2 AUX FUEL TANK
UO1 ROOF MARKER LIGHTS
VO2 TRANS OIL COOLER
XUE 9.50X16.5 TUBELESS
Z53 GAGES VOLTMETER
71W XRR1 RED CUSTOM VINYL
A01 SOFTRAY GLASS
DG4 EXT. B/EYE MIR (7.5"
F60 H.D. FRONT SPRINGS & HEAVY DUTY POWER BRAKES
LF4 400 4B ENG
NA2 STANDARD EMISSION
UA1 4000 WATT HD DELCO F
U63 AM PUSHBUTTON RADIO
U76 TOWING DEVICE
YUE 9.5X16.5 TUBELESS
Z62 SCOTTSDALE EQUIP
9V1 COLOR COMBINATION BL
I GOT THE BASIC VIN DECODE- 78 CHEVY 3/4TON 400CID MADE IN JANESVILLE. SEEMS LIKE A PRETTY WELL ORDERED TRUCK I JUST WISH I KNEW OR COULD VERIFY THAT THE GEARS ARE THE 5.13 THAT IM TOLD
THANKS A TON!
superwade57 is offline   Reply With Quote
Old 10-16-2012, 10:42 PM   #2
Car'n'Guitars
Car'n'Guitars's Avatar
Re: VIN help
I'm pretty positive the only way is if it shows on the SPID in the glove box of the truck, or stamped or a tag that is actually on the axles themselves.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 10-16-2012, 11:28 PM   #3
Jonboy
Slots go on anything!
Re: VIN help
I can't imagine them being that low from the factory, especially being only a 3/4 ton. I would bet they are 3.73 or 4.11, unless the gears have been changed out. 5.13's are awfully low.
1974 Jimmy- 5.3/4L80e/NP241
Old 10-17-2012, 12:03 AM   #4
hatzie
Moderator
hatzie's Avatar
Re: VIN help
X2
20903 is a K20. It would have GT4 3.73 or GT5 4.10 gears with a Dana 44HD axle up front. The only CK trucks with 5.xx gears are the 2wd Cab-N-Chassis trucks with the Dana 70 dually and 19" wheels.
If it really has a Dana 60 up front then it could have anything for gears.
Look behind the front wheel. A Dana 44 has ball joints the 60 has king pins. If dirt is over the top of the axles they're likely hurt bad.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 10-17-2012, 07:11 AM   #5
Keith Seymore
Keith Seymore's Avatar
Re: VIN help
Per the powertrain chart in the GM Heritage Center archives the base axle (and only available axle) for a '78 K20 with the LF4 is a 3.73:1.
Your truck has 3.73's in it, assuming they have not been changed.
K
Link to free downloads of information kits: http://www.gmheritagecenter.com/gm-h...tion-kits.html
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-17-2012, 07:33 AM   #6
superwade57
Re: VIN help
Thanks Keith that's the type of chart I was hoping to see. They may have been changed. Its my dads truck I know its a 350 th400 in it now dad says he remembers it just screaming at road speed And he says 5.13 or 5.38 however he is generally knowledgeable he's also getting forgetful and a 373 scream may seem like. 5.13 20+ years later: ) thanks again they'll be pulled eventually for a.straight. axel convervison on a 93 and ill let you guys know what I come up with then
