Old 10-16-2012, 11:13 PM   #1
oldstyle69
tranny issues
I have a question. First of all I am new to the board this is a great site. I picked up a 72 seirra granda last night. I love it. It is very soild for a Iowa truck. I do not have much history on it but it looks to be about a 10 year old restore. 400 motor 400 turbo, posi, factory air, tilt rallys,tach. I got it running tonight it had been sitting for a couple of years. It runs very nice but the tranny is sluggish going into reverse. When it does engage it slips. It seems to 75% of the time miss first gear completely. Starts in second gear. What do you guys think? I was thinking maybe some stick Valves in the body. Is there a quick fix? has anyone ran into this issue before.
oldstyle69 is offline   Reply With Quote
Old 10-17-2012, 10:37 AM   #2
Wrenchbender Ret
Re: tranny issues
About all you can do is change the fluid & filter. Pull the vacuum hose off the modulator & make sure there is no fuid in it. If that doesn't help it it is time for a rebuild.
Wrenchbender Ret is offline   Reply With Quote
Old 10-17-2012, 04:17 PM   #3
GMCJOE
GMCJOE's Avatar
Re: tranny issues
x2 and in addition change the pump.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 10-17-2012, 04:34 PM   #4
gmachinz
Re: tranny issues
If it's sat a lot of the time with a fairly fresh trans overhaul to begin with-it may be youhave some debris or some dry spots in the housing of the modulator valve. If reverse is ok chances are it's not a worn 1st gear synchro set since on TH400's 1st and reverse share the same ones, you might want to pull the cover off the modulator valve and pull it out-take a lint free cloth soaked in transmission fluid and completely wipe the interior of the housing out and re-install the modulator valve-that might help...if that doesn't make a difference, try adjusting (if it's an adjustable type) the vacuum modulator itself-clockwise lowers the shift point and counterclockwise raises/delays the shift point.
gmachinz is offline   Reply With Quote
Old 10-17-2012, 09:48 PM   #5
oldstyle69
Re: tranny issues
Hey Thanks guys. First is strong but some times skips from a dead stop after you drive it for a bit and goes strait to 2. Reverse slips and locks in after a bit always. Its crazy you can shift to second gear out of drive and it will hold but if you go to 1 out of second it will shift to 3 gear I put some lucus in it and it seems a little better but I will try to clean it up this weekend.
Old 10-17-2012, 10:09 PM   #6
oklalawnboy
oklalawnboy's Avatar
Re: tranny issues
I didn't think the 400 had a modulator. It does have a governor though that could be sticking or a tooth or two broke.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 10-17-2012, 11:23 PM   #7
oldstyle69
Re: tranny issues
Where is the governor located and whats it look like.
69 chevy 3/4 ton 4x4 72 gmc 1/2 ton gmc serria granda
Old 10-18-2012, 12:13 PM   #8
oklalawnboy
Re: tranny issues
If I'm not mistaken, it is on the passenger side about in the middle. Round cover with a spring holding it on. Got to thinking though, The governor may only effect shifting. I had one break because it sat long enough for rust to form on the upper half of the output shaft. (oil level in tranny only covers half the shaft when sitting still) After driving it the vibration from from the governor jumping over the rust finally broke a tooth. This probably doesn't help you at all. sorry.
76 Monte Carlo
