Old 10-17-2012, 07:38 AM   #1
bigd65
bigd65's Avatar
Hydro - boost brakes
Are these brake systems bled the same way as regular brake systems ?
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 10-17-2012, 09:22 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Hydro - boost brakes
Yep.
The boost type does not affect fluid flow through the base brake system.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-18-2012, 12:04 AM   #3
bigd65
bigd65's Avatar
How can you tell if one of these is bad
2017 Chevy Tahoe
Old 10-18-2012, 05:46 AM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
You can't stop lol
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-19-2012, 08:32 AM   #5
bigd65
bigd65's Avatar
That's funny. On vacuum boosters, the pedal gets hard and very hard to stop. This pedal is not hard, in fact goes to the floor only like there is no PRESSURE. does stop but scared when it goes to the floor.
2017 Chevy Tahoe
Old 10-19-2012, 10:28 PM   #6
Phillip Pennartz
Does the pedal get higher when repeatedly pumped? If so then air in the system.
if not then
sounds like master cylinder is leaking internally
Phillip Pennartz is offline   Reply With Quote
Old 10-21-2012, 01:10 AM   #7
bigd65
bigd65's Avatar
No it doesn't pump up, I just didn't know if these brakes were the same as the vacuum booster brakes
2017 Chevy Tahoe
Old 10-21-2012, 11:07 PM   #8
Phillip Pennartz
As far as I know the brake hardware in the wheels is the same,maybe differences in wheel cylinder diameter, but I don't know about the master cylinder of the hydro boost being the same as the master cylinder of the vacuum booster .
might surf to auto parts place website and get part number of each and see if they are the same. They might also may have picx
Old 10-22-2012, 11:09 AM   #9
oldtek
oldtek's Avatar
my suburban has hydroboost and you bleed them just like vacuum brakes. I lost my brakes and found the master was leaking out the back.
oldtek is offline   Reply With Quote
