Old 10-17-2012, 12:25 PM   #1
namdlo
Damper seal leaks sbc
I had a leak out of the damper seal so I thought I ought to fix this. Pretty simple but I have put two new seals in and it leaks worse than the original. I even used a different damper on the 2nd try. What am I doing wrong? Sbc, not sure of exact year of block but had 885 heads and was originally that blue color so I figure late 70's.
namdlo is offline   Reply With Quote
Old 10-17-2012, 04:15 PM   #2
GMCJOE
GMCJOE's Avatar
Re: Damper seal leaks sbc
I usually put some grease around the shaft of the dampener and lip of the seal. They are supposed to be lubed up for install. I would say pull the numbers off the block and decode it. Order the parts and try again.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 10-18-2012, 10:56 AM   #3
namdlo
3rd time and , cross fingers, no more leak. I had put oil on previous 2 trys but a good coat of grease and well I don't want to jinx it.
Old 10-18-2012, 11:45 AM   #4
GMCJOE
GMCJOE's Avatar
Good luck. I have never had a problem after I put a new one in. Can't be much help. They only other reason I could think that you would have a re-occurring leak coming from your front main seal, would be you crank is outta balance causing excessive wobble on the front killing your new seals.
Joseph
Joe's 69 GMC
Old 10-18-2012, 11:57 AM   #5
beautimus
beautimus's Avatar
also, if there is a groove worn on the damper where it contacts the seal, it can cause a persistant leak. In those cases , i have made a wire spacer to keep the seal from going all the way back in the cover. This will move the seal forward just enough to seat on unworn metal , on the damper.
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 10-18-2012, 12:04 PM   #6
mrein3
mrein3's Avatar
What happens is a groove gets cut in the damper shaft where it contacts the seal. Yes, rubber will cut iron after a few million times around.
There are three possible ways to fix it.
1. They make a thin, metal piece that you hammer over your grooved damper shaft where it contacts the seal. I've used these and they work.
2. They make an offset seal so the seal rides around in a new place. I've used these too and they also work.
3. A new damper will also work.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
