Old 10-17-2012, 09:21 PM   #1
exdrocca
trouble installing steering coupler onto steering gearbox
Hi there, I'm switching my '69 c-10 over to power steering. I bought a "new" power steering box from pepboys, and I bought a the steering coupler from LMC, that is to be used with power steering. The splines seem to all line up, but it is a very tight fit. I was wondering if there is a certain way to install this piece. Or maybe I have to wrong part. Just looking for some help.
Thank you
exdrocca is offline   Reply With Quote
Old 10-18-2012, 04:28 PM   #2
Wrenchbender Ret
Re: trouble installing steering coupler onto steering gearbox
There are 2 different size shafts on those. There is a flat spot on the shaft & the joint. If it is lined up right you probably dont have the right size.
Wrenchbender Ret is offline   Reply With Quote
Old 10-18-2012, 06:23 PM   #3
exdrocca
Ahh ok yeah Both shaft and joint have a flat spot. They do line up, but seems as if they would have to be pressed on. Thank you.
Old 10-18-2012, 06:57 PM   #4
plumber36757
Take a socket and tap it on thats what classic told me to do and it went right on.
plumber36757 is offline   Reply With Quote
Old 10-18-2012, 07:12 PM   #5
29od1
You can also count the splines of the rag joint and the steering box shaft to make sure they'll match. I think the two different sizes are 31 spline and 36 spline. It really shouldn't take that much effort to get them together as long as you have the bolt removed from the rag joint.
29od1 is offline   Reply With Quote
Old 10-18-2012, 08:02 PM   #6
whoryou1979
whoryou1979's Avatar
A little force action never hurts.
All Day Every Day
'72 C20 Cheyenne Custom Camper
http://67-72chevytrucks.com/vboard/s...d.php?t=549132
whoryou1979 is offline   Reply With Quote
Old 10-18-2012, 09:11 PM   #7
exdrocca
Ok, thanks for your help. I guess I shouldn't have to ever take them apart again. I will beat that thing on then hah.
Old 10-18-2012, 09:44 PM   #8
kcsa75
kcsa75's Avatar
I'm curious how it turns out. I replaced my steering box a couple of months ago and ran into the same issue. I got the wrong size first, then once I got the right one, I tried beating it on and broke the rag joint.
Finally, I went down to the LMC counter and they had the steering box with the rag joint attached. It was a little more money, but by that time, well worth it. I took the other parts back to O'Reilly got my money back.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 10-18-2012, 10:48 PM   #9
exdrocca
I am hoping to work on it this weekend, so I will let you know how good or bad I make out.
Old 10-21-2012, 08:37 AM   #10
exdrocca
For you who were wondering. So all it took was a little lube, a couple good whacks with a hammer and socket, and the coupling slide right on like it was meant to.
Got another question though. What is the best way to center the wheels, steering wheel while installing pitman arm back on so that I get the same amount of turns left or right and have the steering wheel centered?
Old 10-21-2012, 09:00 AM   #11
cdowns
cdowns's Avatar
i've used a cold chisel to spread the coupler slightly but still needd some forc to drive it on// a light greasing of the splines helps if you need to take it apart 10years from now
Old 10-21-2012, 09:21 AM   #12
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by exdrocca View Post
.......Got another question though. What is the best way to center the wheels, steering wheel while installing pitman arm back on so that I get the same amount of turns left or right and have the steering wheel centered?
Normally, one would take it to a shop that specializes in front ends but if you need to get it close raise the front tires and check to make sure the gearbox input shaft is centered by counting the steering wheel turns left and right.
After you make sure steering gearbox is centered loosen the tie rod end clamps on both wheels and turn each one the same amount to get the wheels as close to straight as you can and then drive it to an alignment shop.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 10-21-2012, 12:11 PM   #13
whoryou1979
I agree with 68gmsee. In the future, I would try to center the wheels and steering wheel before installing. Makes it easier.
All Day Every Day
