Old 10-17-2012, 09:44 PM   #1
gabe2000
sunpro 33-240ohm????
can i use both gas gauge and senting unit from Sunpro??????? I am not getting a clear answer on other thread. My gas gauge is starting to failed and i am in processes of puttiing a new underbed gas tank.
gabe2000 is offline   Reply With Quote
Old 10-17-2012, 09:53 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: sunpro 33-240ohm????
As long as the sender and the gauge are the same ohm yes...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 10-19-2012, 01:21 PM   #3
gabe2000
thanks. I was about to order them when I saw that both are
240ohms- 33ohms (backwards). this is compatible with my 64 GMC truck original wiring????
anwser are free and welcome
Old 10-19-2012, 01:37 PM   #4
Rich 5150 69
It may or may not be, before install hook up stock wiring and test it, if not follow instructions that come with it. One thing to be sure tank is well grounded to frame and frame to cab...
Old 10-19-2012, 04:25 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
GM to my knowledge has only used two Ohm ratings until maybe late model stuff (post 2000). 0-30 and 0-90. Many of the aftermarket ones that are generic and not GM specific tended to use 33-240. I think that dates back to a Stewart Warner thing way back in the day.
Oh, I guess I misread things. The wiring itself is fine to use if in good shape but your sender and gauge must match. There are only about 5 different ones typically found. Ford has their own and I think I have seen one other one than the three I listed above.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
