Old 10-17-2012, 10:07 PM   #1
gmachinz
208 to 205 TC swap question...
Okay-I bought an 86 4X4 project truck from somebody else who basically dropped a standard 2WD cab and box on a shortbox 4X4 frame with no lift and the drivetrain based on the casting numbers is a 74-77 vintage 205 transfer case and a GM Goodwrench crate 350 with a TH350 trans.
In my quest to make the interior as correct as possible, I have added the 4x4 light socket and switch wiring which would extend down to the transfer case through the hole in the floor but I can't find any info on what parts I need to have the 4x4 shifter actuate the switch-I have a few spare 208 brackets and obviously the throws for a 205 are basically opposite and I seen a few 205 equipped trucks at local boneyards but they too lack the 4x4 switch and bracket as well. Am I just having bad luck or what? I need to know what to look for in terms of the correct switch bracket....anybody have an exploded view of the parts required to make it work?
gmachinz is offline   Reply With Quote
