Old 10-17-2012, 10:51 PM   #1
Awillman13
Gas gauge problems.
I have a '73 K10 with passenger side single tank. My gas gauge is on about 3/4 tank and never moves. Any ideas where to start trouble shooting?
Thanks,
Andrew
Awillman13 is offline   Reply With Quote
Old 10-17-2012, 11:09 PM   #2
cal30_sniper
cal30_sniper's Avatar
Re: Gas gauge problems.
Thanks,
Andrew
Most likely a bad or stuck sending unit, a sunk float will usually leave the gas gauge on Empty.
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress
73 Formula - 400/Doug Nash 4+1, resto on hold
86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale
01 Ram 2500 - 5.9L Magnum, daily driver
91 BMW 325i - Chumpcar series racecar
cal30_sniper is offline   Reply With Quote
Old 10-17-2012, 11:14 PM   #3
Awillman13
Looks like I'm pulling the tank.
Old 10-18-2012, 05:12 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
if you can ground the sending wire should go to E
left off should go over full
and check the ground back there,may wana add a temp one just to test even
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
