Old 10-17-2012, 10:58 PM   #1
Painter D
Painter D's Avatar
What year motor?
Is there any way to tell what year motor I have? All I know is tht it came out of an Escalade.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 10-18-2012, 10:05 AM   #2
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: What year motor?
If it came with the ECM, you can scan the VIN out of it and will be able to tell. Other than that, can you post a pic? There are a few external cues that can help narrow it down.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-18-2012, 10:12 AM   #3
Painter D
Painter D's Avatar
Thanks ill try to post some pics later this evening.
Old 10-18-2012, 09:37 PM   #4
Painter D
Painter D's Avatar
Here's a few
Old 10-18-2012, 10:25 PM   #5
65Gregg
65Gregg's Avatar
On the rear passenger side of the block is a number cast in the block, the second digit is supposed to be the year.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 10-18-2012, 10:30 PM   #6
ls1nova71
ls1nova71's Avatar
It's definitley a 2003 -up. Judging by the return style fuel rail, I'd say it's a 2003, most '04 and up were returnless unless they were flex fuel. That said, most parts have casting years on them, look closely and you'll see a little round symbol with a number in it, that's the year the part was cast. Underside of the valve covers, aluminum part of throttle body, inside the oil pan, on the back side of the A/C mount bracket are just a few places to look.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-18-2012, 10:35 PM   #7
clinebarger
'03
clinebarger is offline   Reply With Quote
Old 10-18-2012, 10:36 PM   #8
clinebarger
Beat me to it
Old 10-18-2012, 11:01 PM   #9
ls1nova71
ls1nova71's Avatar
Originally Posted by clinebarger View Post
Beat me to it
My typing skills must be getting better, it's hard to beat you to anything!
Old 10-18-2012, 11:22 PM   #10
Painter D
Painter D's Avatar
Well the second digit on the back of the pass. Side of the block is a 2. The number on the aluminum part of the throttle body is 03, couldnt see any more numbers anywhere (its dark)
Some of you guys mentioned the return fuel line ,which line is the return line and which one is the feed line? Also, does this mean I dont need the vette filter? Is the regulator built into one of the lines? (thought I read that somewhere)
Old 10-18-2012, 11:56 PM   #11
ls1nova71
ls1nova71's Avatar
The feed line is the 3/8, the return is the 5/16. You don't need the 'Vette filter with this set up. The regulator is on the fuel rail, it's the round part with a little vacuum line going to it.
Old 10-19-2012, 09:32 AM   #12
Wasted Income
Boosted Member
Now that we've narrowed it down to 02/03 you should be good to go. There are no differences between those two years. Any parts you order for one, will fit the other.
What are your plans for this engine?
Turbo diesel
Old 10-19-2012, 10:14 AM   #13
ls1nova71
ls1nova71's Avatar
Actually there are quite a few differences between '02 and '03. 2000-2002 throttle bodies are the same, and 2003 to 2007 are the same. They each use a different TAC module and the harnesses are different due to the different throttle body. Pre 2003 PCM wil bhave blue and red connectors and 2003 to 2007 are blue and green.
Old 10-19-2012, 10:26 AM   #14
Wasted Income
Boosted Member
Ah dammit....I don't mess around with any of that DBW nonsense With all my builds, the DBW TB goes in the dumpster, and a cable TB and 0411 goes back on
What trucks used a DBW throttle body in 2000? I thought 2001 was the first year for the C3/Denali/Escalade to use that TB?
Regardless, I should have specified that I was referring to the base engine.
Turbo diesel
Old 10-19-2012, 11:08 AM   #15
thump16
thump16's Avatar
my 04 in my c10 is DBW single feed fuel line off of the rail.
thump16 is offline   Reply With Quote
Old 10-19-2012, 11:38 AM   #16
Painter D
Painter D's Avatar
Im gonna put in my 58swb chevy truck, probably just run a mild tune and call it a day. From the sounds of it ,it would be easier for me to run the dbc throttle body. Can any of you guys recommend a wiring harness for this?
Old 10-19-2012, 12:52 PM   #17
65Gregg
65Gregg's Avatar
Smile Re: What year motor?
It sounds like you and I are in the same boat, we have an engine and need tons of information to figure out what to do with it. LOL. I think I'm gonna follow your progress and try to learn.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 10-19-2012, 01:25 PM   #18
Wasted Income
Boosted Member
Did your engine come with an PCM and TAC module? If so, it would be the easiest to stay with that.
To switch to DBC, you'd need an older red/blue PCM and matching DBC harness (DBW harnesses don't have a provision for IAC stepper motor...they use the throttle blade for IAC.)
I normally switch over to DBC because with my turbo setups I like to go 2 bar, speed density tunes, which a the time were only available for DBC PCMs.
I've since gotten away from all the OBD2 stuff and went Megasquirt/Megashift.
Turbo diesel
Old 10-19-2012, 02:16 PM   #19
Painter D
Painter D's Avatar
Ok first what does pcm, and tac , and iac stand for? My engine came with the computer if thats what youre referring to. I was planning on buying a new stand alone harness which is why I was thinking dbc would be easiest.
Feel free to correct me if Im way off on my thinking.
Old 10-19-2012, 02:52 PM   #20
Wasted Income
Boosted Member
Well OMG, WTF....IDK. Haha, ok. I will start on page 1.
PCM = Powertrain control module (controls engine and transmission) = computer
DBC = Drive by Cable
DBW = Drive by Wire
TAC = Throttle Actuation Controller (electronic pedal)
IAC = Idle Air Control
TB = Throttle Body
Turbo diesel
Old 10-19-2012, 03:10 PM   #21
Painter D
Painter D's Avatar
Ok , gotcha. I did not get the tac with the motor, which is why I figured the dbc harness and dbc throttle body would be the best way to go. Or am I way off here. Lol
What would be the easiest setup to do with what I have?
Old 10-19-2012, 03:55 PM   #22
Wasted Income
Boosted Member
Personally, if you're planning to buy a stand alone harness....I'd get one for a DBC setup, find a truck cable throttle body, and PCM.
Not sure about where you're at...but my local pick-a-part has throttle bodies and PCMs everywhere.
I would find a PCM with the service code "12200411" and have it flashed for your setup. Doesn't matter if it was originally on a V6 or V8....manual or auto. If the serv. # ends in 0411 it can be flashed with the correct operating system for you.
Turbo diesel
Old 10-19-2012, 04:01 PM   #23
Wasted Income
Boosted Member
Here you go.
0411 PCMs for sale
Turbo diesel
Old 10-19-2012, 06:49 PM   #24
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Source on this? When I was sourcing my pcm, my tuner informed me that for my swap (dbw 6l/4l80e, 2003/04) I had to get a v8/auto pcm, because the manual trans pcm had problems with the second vss sensor input from the 4l80e.
On another note, while I agree that its an 03/04 motor, do we KNOW that its actually an Lq9? No external differences from the lq4, I've seen "escalade" motors on CL before that were just lq4's, which is still a great motor.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-19-2012, 08:12 PM   #25
Painter D
Painter D's Avatar
Well how do I find this out? Let me know and Ill get on it.
