Old 10-18-2012, 01:03 AM   #1
melhilburn
melhilburn's Avatar
dash lights
need to get all my dash lights working correctly - Electrical is my weakest link -Can someone explain this to me like I'm a two years old - Please
melhilburn is offline   Reply With Quote
Old 10-18-2012, 08:19 AM   #2
1963c-10
1963c-10's Avatar
Re: dash lights
Whats wrong with them? Could just be the cluster needs pulled and bulbs replaced. To turn the dash lights on, you will turn the headlight switch to the left. When it clicks...the dome light will come on.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-18-2012, 03:37 PM   #3
melhilburn
melhilburn's Avatar
Re: dash lights
well when I pull it to the first click the dome light doesn't come on - I'll start with the dome light bulb - Like I said electric is my weakest link
Old 10-18-2012, 03:49 PM   #4
melhilburn
melhilburn's Avatar
Re: dash lights
This may sound random but where is the correct location to place the jack for front and rear of the truck ???? - to safely change tires etc. - I'm smarter than this but I'm begining to wonder
Old 10-18-2012, 04:01 PM   #5
1963c-10
1963c-10's Avatar
Re: dash lights
LIGHTS.... if you pull it out one click, this will turn on your parking lights(hood) and tail lights. Pull it out to second position and the headlight/taillights will operate. If you TURN the knob to the left, this will change the brightness of the dash lights from dim to high. If you TURN it to the left and feel the click...thats the dome light on. JACK normally put it on the frame rail for the rear and go on the crossmember for the front. If you look under the driver side seat, there should be a mount that holds the jack. (if its still there.... for storage).
Old 10-19-2012, 06:12 AM   #6
melhilburn
melhilburn's Avatar
Re: dash lights
My emergency brake cables just came in so I need to replace them this weekend - It shouldn't be any big deal but if I run into somthing odd I'll post it the questions - check under the seat my luck no jack.
