Old 10-18-2012, 05:05 AM   #1
kevinc
kevinc's Avatar
What to put between frame and conv. plate?
I have my 5.3L ready to be installed. I have my motor mount conversion plates. What motor mounts do I install that go between the original engine frame stands and the conversion plates?
Thanks,
Kevin C
1988 C1500 Regular Cab, Long Bed, 2WD.
kevinc is offline   Reply With Quote
Old 10-18-2012, 12:35 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: What to put between frame and conv. plate?
plates onto block, sbc mounts onto engine perches. Drop one down into the other.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-18-2012, 10:35 PM   #3
ls1nova71
ls1nova71's Avatar
There's several different kinds of small block motor mounts, use what ever style motor mounts originally went to your stands.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-19-2012, 10:12 AM   #4
kevinc
kevinc's Avatar
That's the tricky part. My truck came as a roller with no engine so all I have is the frame stands that are attached to the top of the frame and the other end attached to the cross member. The original motor mounts were not there so I don't know what style mounts I need. Would you have a part number or a source to get them?
Thanks,
kevin C
Old 10-19-2012, 12:41 PM   #5
kevinc
kevinc's Avatar
Here's a picture of the engine bay so you know what I'm getting at.
Kevin C
Old 10-19-2012, 06:33 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
pics of the engine perches and where they bolt up would help, but I'll take a shot.
The perches between the 6 and 8's mount in different positions, so when coupling them with mounts and swap plates, the engine positions may change. The I6 and v8 perches BOTH can accept SBC motor mounts.
I used TransDapt swap plates, I6 perches (moved to the FRONT set of bolt holes). You'll notice the perches can bolt in 2 locations, and if your willing to drill a new hole, you have plenty of room to move the engine forward or backward as needed.
My combo is I6 perches, Transdapt swap plates in the "regular" position (they can be used to set engine back another 1"), and 72 SBC motor mounts. The 63--72 sbc mounts are all the same and will work fine. My engine clears the fire wall by an easy 1/2", which was the minimum I was comfortable with to run fuel lines etc. If you relocated COP coils and don't run an engine cover, you can move it even closer.
Old 10-20-2012, 08:33 AM   #7
kevinc
kevinc's Avatar
Here's a better picture of the cross member and the location of the frame mounts. The previous owner said he had a small block in it, but he said lots of things just to find out he didn't do it. He may have had a I6 in there for all I know.
I also included a picture of the type of conversion plate I'm using.
I would like to have the engine sitting farther back if possible. Please advise.
Old 10-20-2012, 10:20 AM   #8
ls1nova71
ls1nova71's Avatar
I'm not familiar with the older ones, but those stands look just like 67-72 small block stands so I would say that mounts for a SB 67-72 would work. You need mounts that bolt on from the bottom up, through the center hole in the stand.
Old 10-20-2012, 10:28 AM   #9
ls1nova71
ls1nova71's Avatar
Now that I looked at the pic again... they kind of do look like they're in the I6 position. So the engine will probably be set back further than stock. Since that's what you want. I would just stab the engine in and see how it looks.
