Valve cover and side panel gaskets 292
Best place to find valve cover and side panel gaskets - Also do I have to remove the distributor to install the front side panel gasket?
Re: Valve cover and side panel gaskets 292
I get my gaskets fom NAPA or O'Reilys here. We also have advanced Auto and Western Auto. The front cover will come off....it'll be tight, but I did my 230 side covers w/o removing the dist.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
It's Better With Nitro
If you're local parts house does not carry them, you can still order them online at Summit Racing. And, yes, for the 292, you'll need to remove the distributor to unbolt an remove the forward side/push rod cover.
