Hi all,
I have a 1965 GMC with the 305 V6. It has started acting up, by losing power under load. When climbing a hill I have to shift down just to keep it at 40 if I am lucky. Starting from a stop it really drags. I gave it a full tune up with new points and nothing. I timed the engine and nothing. The carb is less than 2 years old and adjusting the fuel mixture hasn't helped. I converted to an electric fuel pump. Didn't help The engine has a rebuild less than 50k. I am at a total loss. I am trying to keep it running long enough to get my 327 from my fathers place which is unfortunately out of town. Any help or suggestions would be greatly appreciated. Mark ![]() |
Re: No Power under load
Whats your fuel pressure? Sounds to me like a fuel pressure issue if runs fine except under load or going uphill.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Thanks for the reply. I was doing some reading and found that when i set the timing at 5 degrees off of TDC, it is actually around 2.5 or 2.7. When I timed it I also did not disconnect the vacuum advance line so it may be way off. If timing it correctly does not fix the issue I will check fuel pressure.
Thanks, Mark ![]() |
Sounds like a plan.
Chevy addict
Catalytic converter is plugged ! B>}
#6 | |
![]() Quote:
What carb is on it?? I would check to make sure that the centrifical advance didnt freeze up . you can check it with your timing light by disconnecting the vacum advance and rev it up while watching the marks it should advance as engine speed increases.... also the power valve can get stuck causing a lean mid throttle , used to happen with Qjets all the time....
