Old 10-18-2012, 11:11 AM   #1
76k10
Front driveshaft needed
Where do y'all recommend getting a custome front shaft made? Local shop wanted $290 to redo and lengthen my shaft.
76k10 is offline   Reply With Quote
Old 10-22-2012, 11:52 PM   #2
Scott Johnson
Junior Member
Scott Johnson's Avatar
Re: Front driveshaft needed
Sounds about right, my local shop charged me $275. You can try Dennys Driveshafts also, heard good things about them.
http://www.dennysdriveshaft.com/
71 C10 Step Daily Driver
72 K10 Suburban Work in Progress
www.louisianaclassictruckclub.com
Scott Johnson is offline   Reply With Quote
Old 10-23-2012, 01:58 AM   #3
kenbob87
kenbob87's Avatar
i got mine from high angle drive in cali..... it was about 3x that lol
kenbob87 is offline   Reply With Quote
Old 10-23-2012, 02:03 AM   #4
Redcap
Ouch. They saw you coming...
Redcap is offline   Reply With Quote
Old 10-26-2012, 12:36 PM   #5
kenbob87
kenbob87's Avatar
yeah they did but it will be almost impossible to break it it has 1410 u joints the slip joint will slide in and out about 18 inches and will run at up to a 42 degree angle
top shaft is the stock one bottom shaft is the one from high angle drive
Old 10-26-2012, 10:04 PM   #6
odog
odog's Avatar
Kenbob Id say you got your $275 worth on that shaft, it looks ready to take a beating and maybe do a little beating in return. That thing looks sweet!
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 10-27-2012, 01:59 PM   #7
kenbob87
kenbob87's Avatar
not 275....900 and some change but i got really tired of having to bring 3 or 4 front shafts with me every time i wanted to go do some wheeling.
Old 10-27-2012, 02:04 PM   #8
odog
odog's Avatar
Ok $900 Its still a sweet drive shaft
1969 4x4
