GMC 351 V6 Engine Mount
Does anybody know if the engine mounts stayed same style/size from the pickups up to heavy duty trucks? I have 69 GMC 7500 with the 351 and looking for engine mounts.
1990 Chevy C2500 4x2 350TBI 1997 Chevy K1500 4x4 350Vortec |
![]() Join Date: May 2007
Re: GMC 351 V6 Engine Mount
Hmmm that's a question that I never thought about but would like to know.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
![]() Join Date: Feb 2011
Would post a pic of the style you have now. Curious to see what you have going.
MusicMan70 1961 GMC Suburban |
![]() Join Date: Aug 2005
The rear (bellhousing) mounts on a V-6 pickup with a manual transmission are the same as a medium duty. GMC V-6 medium duty trucks used a single front mount that bolts to the timing cover, not the mounts on either side that bolt to the block that the pickups use.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
Do you got pic of the medium duty mounts that bolt to the timing cover?
#7 | |
The mount for this was a single rectangular almost square piece of rubber.
So what I need here for the medium duty V6?
So all I have is front and rear mount?
Two rear and one front I believe. May what to PM Bob B. on that. What I posted is all I have.
Also Dave did you notice the rear set-up in the video. Is your similar to this one? I thought the video was fairly comprehensive and useful.
I'll have to compare with I have. I the medium duty manual trany setup on mine too. I'm thinkin its clark or splicer. Dont know if its sm465 since its a medium duty.
#13 |
So where do I get mounts at for this setup?
#14 |
Anybody else?
#15 |
![]() Join Date: Mar 2002
Go over to Jolly's 60-66 GMC V6 site for more info.
1968 GMC 305 V6 3/4 4x4 Stepside 06 Corvette Daily Driver Dallas TX |
#16 |
Not getting any help over there or stovebolt site either.
#17 |
I think the rears are the same for most any GM medium duty truck with a gas engine and manual transmission, up into the 80's. That front cushion is going to be tough. It goes between that rectangle part that bolts to the front cover and the chassis crossmember. Just a square block, you might be able to match up a transmission mount from some other vehicle.
