Interesting cl find
you don't see these every day!
vermont craigslist > for sale / wanted > cars & trucks - by owner 1962 gmc 702 cu in motor - $3000 (Brandon ) http://burlington.craigslist.org/cto/3304742624.html |
Re: Interesting cl find
Pretty interesting engines. Saw an article about them in Car Craft last month. Thunder V12 is a company that is rebuilding them. Trouble is - I'm not sure what you could put it in . . .
Cool to think about though. See more here: http://thunderv12.com Posted via Mobile Device |
1961 crewcab
wish he had posted a pic of the truck
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Man, a sheetmetal intake with a few big Holley carbs, a reground cam, port and polish all the heads, I've heard there are big-valve heads for the V6 so those probably flow better to begin with, custom pistons for high compression and a set of good rods... 1.25hp per cubic inch should be do-able.
Then drop that heavy sucker in a '53 Studebaker and go set a record at Bonneville. Yes, I have thought about just exactly this in the past... Comparatively speaking, it probably wouldn't be a real expensive way to build a 700ci engine... Probably a lot cheaper than building one that big based off a Big Block Chevy or other aftermarket block/head combination. I wonder what 702ci + .030-over comes out to? And at Bonneville, weight isn't a bad thing. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School Last edited by Brad54; 10-19-2012 at 06:47 PM. |
#5 | |
![]() Join Date: Oct 2012
Thank you. I knew I had just read an article about these also, but couldn't remember which one of my monthly rags it was in. Makes me wonder what kind of truck it's in, that's a pretty long setup. |
Who Me?
Ive only seen those in pictures.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
1961 crewcab
they are in the "lcf " version of the gmc
#9 | |
1961 crewcab
I have yet to see an "under hood" shot of one in a 60-66 gmc lcf
![]() ![]() ron |
