any other power steering parts needed?
so i came across a power steering assembly from a guys parts truck i may grab.
has the pump(with bracket), lines, pitman arm and gearbox that came off a 70 c10 to go on my manual steer 70 c15. also, they po (before the guy using it as a parts truck) was driving the truck, but current owner never did. so... do the gear boxes usually get alot of play in them? who knows if the oil on it is from the steering or just a mess from the old truck and motor it was living with, so then i may need to throw new gaskets in it. am i money ahead to just buy all the stuff new and spend the extra few hundred bucks? of course then id need to buy EVERY part to make it work on mine. |
I am a Referee of life.
Re: any other power steering parts needed?
I would clean it up,maybe paint it.Then install and see what it does.replace only what needs it.If you have a spotless engine compartment then I would only go new.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: Jul 2007
You might need the crank pulley for ps, clamp for holding the hoses to the frame, and a belt. I don't know the # for the belt, I need one myself.
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
ok. ill have to look at the pulleys again to refresh my memory, but i think ive go an axtra grove for it already on the crank. which would be nice since as it seems, the guy has this and only this left.
but its still a good start! |
you can buy a rebuild kit for them on rockauto, might as well rebuild it while its out, pretty easy to do, and there are a couple step by step sites out there that can show you how, maybe get the pitman arm too while you're there
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott 1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064 1930 Tudor Sedan |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Your mounting bracket looks like it is for a short water pump cause it's different than mine. I have the long water pump. You can still mount it up and see if it lines up.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
