Old 10-18-2012, 06:08 PM   #1
carwhore
carwhore's Avatar
Best way to lower a truck on air----the cheapest
What have you guys done/used to c-notch and lower your trucks.
I want to lower mine, but the prices on everything add up quickly.
What do you need and what don't you need?
I want to retain my factory bed.
carwhore is offline   Reply With Quote
Old 10-18-2012, 06:18 PM   #2
Billett
Billett's Avatar
Re: Best way to lower a truck on air----the cheapest
Not to be whatever, but bagging a truck and cheap don't usually work together. I haven't done a c10 before, but just be prepared. It's going to cost a lot more than you think to have a good reliable setup.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 10-18-2012, 06:21 PM   #3
carwhore
carwhore's Avatar
im going to do most of the work myself and have a great mechanic I use that will do everything else I can't. So im not worried about labor.
I basically want to see what route everyone took with their builds.
What parts did they buy
which air ride set up. Or did they piece it together.
Old 10-18-2012, 06:31 PM   #4
Sillyoldman
#16876
Sillyoldman's Avatar
You can air down your tires (jk)
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 10-18-2012, 06:36 PM   #5
Billett
Billett's Avatar
check the vendors section. Usually some pretty good deals. It will at least give you a start. I hear a lot of good things about porterbuilt
Will
2024 Toyota Sienna
Old 10-18-2012, 08:02 PM   #6
Square_78
Square_78's Avatar
You can get all the bolt in brackets for the truck and bolt in c-notch pretty cheap. Front and rear bags are cheap also and you can just hook them up to shrader valves for now, and then buy the tank and compressors later if you want.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
