Old 10-18-2012, 06:12 PM   #1
65truckowner
65truckowner's Avatar
protect o plate decoding
I have the protect o plate for a 65 chevy truck I have. Does anyone know what the engine code f1228w z and the transmission code m1230 mean?
65truckowner is offline   Reply With Quote
Old 10-18-2012, 07:17 PM   #2
yelmer
Re: protect o plate decoding
is that from the owners manual? or the vin tag on the door?
yelmer is offline   Reply With Quote
Old 10-18-2012, 07:31 PM   #3
yelmer
the engine codes for 65 chevy truck with a "w" in it are "we" which is 283 with powerglide and "wa" which is manual trans is that a " wz" ? the date code is dec 28
Old 10-18-2012, 07:31 PM   #4
yelmer
the f is the motor was built in flint engine plant
Old 10-18-2012, 07:44 PM   #5
65truckowner
I found this in the owners manual. The plate down by the drivers side kick panel has been painted. So it came with a 283? and a three speed?. The axle code is he1228w
Old 10-18-2012, 08:00 PM   #6
yelmer
"he" says that the ratio is a 3.73 std axle c15 truck . Is your truck a 1/2 ton
Old 10-18-2012, 08:01 PM   #7
yelmer
Do you have a picture of the protecto plate?
Old 10-18-2012, 08:22 PM   #8
corvettejim1968
corvettejim1968's Avatar
could you help me with mine as well.
trans # M0217
Engine # F0218TF B
axel # HE215W Y
engine block F111OXTB
F8216913
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 10-18-2012, 08:47 PM   #9
yelmer
Hello corvetejim . The axle is a 3.73 std axle now your engine number is it 2 letter at the end or 3 . "tf" i show it as a 250 engine 4 speed tranny hd clutch that is for engine "tf" . Does that look right to you? Also i show it for a 1966 chevy truck
Old 10-18-2012, 08:53 PM   #10
65truckowner
Yes mine is a 1/2 ton. If it came out with a 283 I have one sitting beside it on an engine stand that I am going to put back in it. I just thought it came out with a 6 and was going to put in a 350
Old 10-18-2012, 08:57 PM   #11
yelmer
Corvettejim if it is "tfb" i show it as a 1972 350 van or bus or 1980 and 1982 van and bus and conv cab 4 barrel carb 350 c-10 1500 and c10-2500 truck manual trans . If you have the three letter code . This is what comes up . What year is your truck? Was the engine replaced?.
Old 10-18-2012, 09:06 PM   #12
yelmer
It is very hard to tell what came in the early year trucks the vin does not tell .sometimes you need to look at the engine mounts , but those can be changed . Sometimes the vin can tell you the month built and the motor date will line up . You are probably have the original motor if they are close unless somebody knows to get a close date code motor . The protecto plate in the owners manual will match the pad number on the block . Then you know its the right motor . But many times the protecto plate is gone to check this .
Old 10-19-2012, 08:26 PM   #13
corvettejim1968
the truck is a 1965 c10 . records show the engine was rebuilt in 1980 for $750
Old 10-19-2012, 09:10 PM   #14
yelmer
if that number from the plate is on your engine pad that is the original motor. the motor was built feb 18 1965 . it is a 250 4 speed trans heavy duty clutch .
Old 10-19-2012, 09:56 PM   #15
Shooters_7
How about a TA instead of a TF, what engine is this?
Shooters_7 is offline   Reply With Quote
Old 10-19-2012, 10:05 PM   #16
yelmer
'ta" is a 1965 230 with a 3 speed trans
Old 10-19-2012, 10:23 PM   #17
corvettejim1968
i find that interesting because the 250 is not one of the 1965 engine options plus i have a low hump not a high hump.
Old 10-20-2012, 08:43 AM   #18
yelmer
The book states that the tf engine came out in 66 as a 250 the list has a " te" which is a 230 with powerglide for 65 the numbers listed are ta te tg th ti tj tk that is for 1965 that is strange?
Old 10-20-2012, 08:47 AM   #19
yelmer
Your rear end was built feb 15 1965 at the warren plant
Old 10-21-2012, 12:48 PM   #20
duallyjams
duallyjams's Avatar
here's mine
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 10-21-2012, 08:01 PM   #21
yelmer
could you give me a better picture i can't see it very well thanks
Old 10-22-2012, 08:51 AM   #22
duallyjams
duallyjams's Avatar
hope this is easier to see
James
IG duallyjams
Old 10-22-2012, 06:55 PM   #23
yelmer
thank you much better. From the plate the engine was built in flint. motor was in the factory and stamped dec 07 1964 "WE"is the engine code shows 283 with powerguilde. the axle was stamped dec 04 1964 the "HA" shows 3.73 . exc. positraction for a c14 shortbox built in warren plant. paint code 533 is light green and off - white . i do not have a breakdown on the trans . but from the engine code it is a pg. stamped dec 03 1964 the "c" might refer to Cleveland . your truck was assembled in St Louis .it was the 29984th truck built on that line for 1965 model year.
Old 10-22-2012, 07:37 PM   #24
duallyjams
duallyjams's Avatar
many thanks
James
IG duallyjams
