Old 10-19-2012, 12:26 PM   #1
mongoose
mongoose's Avatar
couple 4x4 fab. questions..
Trying to piece together a new truck and have a couple questions...
Front axle.. What is the proper angle for the shackle at ride height? Angled back or forwards...
And, does it matter if the shackle is on the front of the leaf? Trying to keep it as low as possible so I'm thinking I can gain an inch or more by having the shackle in the front..
Thanks.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 10-19-2012, 03:21 PM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: couple 4x4 fab. questions..
Not quite sure what your trying to do here, but... The stock springs in the front are negative arch and the shackle is angled back. Lift spring shackles are angled towards the front. I've never seen one with the shackle in the front of the spring, but Scouts and Jeeps do it that way, so it must be ok.
You could also do a slider instead of a shackle to keep the height down.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-19-2012, 05:08 PM   #3
mongoose
mongoose's Avatar
Full size blazer drivetrain into a s10 blazer.. Bush/hunting rig.. But would rather not lift it a bunch to make it work.. Low CG build..
