Old 10-19-2012, 07:23 PM   #1
bignbad
bignbad's Avatar
4 or 6 inch lift why did you choose
like it says why did you choose 1 or the other?benefits of each 1 pros and cons and so on and what kind and why did you choose 1 kind/maker over another?
oh what do you have it on and what year? Tire size also.... just getting ideas and unsure how hi i want to lift my 72 k20 pick up truck..
thanks
'72 chevy k20
'06 H-D Springer softail
http://www.bluemooncruisers.com/
http://www.enginecycle.com/
~Eric
bignbad is offline   Reply With Quote
Old 10-20-2012, 07:50 AM   #2
liftlawssuck
liftlawssuck's Avatar
Re: 4 or 6 inch lift why did you choose
I choose a 4 inch for my 71. I just wanted a nice solid looking truck with 33's. I didn't want to get pulled over buy the cops either. Been there done that. To me a 4 inch lift is stock. lol. I put a 6 inch lift in my 79 because I wanted big. Also had a 3 inch body lift then took it out back to 6 inch. But as I 'm redoing it again I put a 4 inch in for the reasons above. Don't want to hassled anymore. As far as mods it was same on both. Driveshafts, brake lines, steering arm, e-brake. They are both shortbeds. I just really like the look of a 4 inch lift with 33's. They just have a nice look to them.
liftlawssuck is offline   Reply With Quote
Old 10-21-2012, 12:57 AM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
I went 4". Mainly to get the truck up to allow for larger tires without having an excessively tippy feeling in off camber situations. I put 35's on shortly after the lift and it suits my needs well. I also didn't want to deal with dealing with hiking my large tail into it when ever I wanted to drive it.
A 6" lift on my rig would have been overkill.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 10-21-2012, 01:26 PM   #4
Your41Plague12
Your41Plague12's Avatar
I have 6" in the suspension, 3" in the body, and 38x15.50's. I think the 6" suited my needs better, but I should have went 8 and ditched the body lift. It actually cleared the 38's with very minor trimming without the body lift. This is on an 83 K20.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 10-21-2012, 02:03 PM   #5
Redcap
I went with a 6" lift, as I'm running 35x12.5s and didn't want to trim yet. If I want to go larger, I'll either cut fenders or put in a 1" body lift.
Redcap is offline   Reply With Quote
Old 10-21-2012, 08:49 PM   #6
liftlawssuck
Forgot to mention that the higher you go with a 67-72 the rear tire is closer to the forward wheel well opening and looks funny. Not sure why this happens but they all seem to do it.
Old 10-22-2012, 12:22 AM   #7
Mr. 250r
Mr. 250r's Avatar
4in suspension with a 3in body clearing 38.5s on not sure what exact wheel size but i won't ever go higher because its not needed
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 10-22-2012, 01:08 AM   #8
Thebeast72
Thebeast72's Avatar
there was a 3" Body lift on my 72 gmc when i Bought it But it wouldn't clear 35's so i put in some new 4" softride springs. going to ditch the Body lift as soon as i can get a new set of Body mounts. i also have a 4" rough country with cut fenders on my 77 stepside running 38.5 Boggers.
Thebeast72 is offline   Reply With Quote
Old 10-25-2012, 03:02 PM   #9
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I got a 6" suspension lift and 3" body on my '79 running 39.5" TSL swampers. Kinda wish it didn't have the body lift on it now but oh well. Someday might take it off and toss it away. I really like the way 6" lifts and 35"s look. Hows the truck going to be used hardcore wheeling or just moderate wheeling. I would figure out how its gonna be used then what size tires you want to run then look at lifts but that's me.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 10-26-2012, 02:11 AM   #10
mcmlxix
Collector of Projects
mcmlxix's Avatar
My 72 Blazer came to me with I believe is 4" front springs and rear blocks. I replaced the body mounts and added a 1" aluminum body lift blocks. I like that it helps clear hoses and exhaust near the frame and body. I wouldn't go more than a 1" body lift. The front springs will stay and I am replacing the rear lift blocks with a shackle flip kit from DIY4x. I like the DIY4x kit because it uses simple shackles that you can adjust the length, and in turn ride height. I had 33" tires on it and will be running 35's when done...
Rich
1972 K5 Blazer CST Click HERE
Old 11-04-2012, 12:15 AM   #11
belldar
belldar's Avatar
6 inch lift. chose it so the 35s would not rub. Still rub a bit due to the 2.5 inch backspace on my procomp 52 16x8 rims. Wouldn't change a thing so far!
belldar is offline   Reply With Quote
Old 11-04-2012, 03:05 PM   #12
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
4 inch (front spring and shackle flip rear) to keep a lowish center of gravity. I run 35s in the winter and will throw on 37s with trimming this spring. I also fit the burb's taller roof line in a standard garage which is a plus.
I also clocked my transfer case and tucked everything up for extra ground clearance.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 11-04-2012, 05:16 PM   #13
woodwright
Enjoying left field
woodwright's Avatar
Did new 52" springs in the front, and a shackle flip in the rear with 54's on my 70. I think its about 5".
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 11-09-2012, 06:36 PM   #14
riz
Do you have pics of your set up? it's what mine will have once complete but rather 4" suspension and 2" body with 35" tires.
Thanks in advance.
RIZ
riz is offline   Reply With Quote
Old 11-10-2012, 04:11 AM   #15
Redcap
Thanks in advance.
RIZ
Old 11-11-2012, 12:54 AM   #16
argonaut
argonaut's Avatar
My rule is only go as high as you need to clear the tires you want to use. Unless you just like the look of lifted truck and it is only street driven, you want the center of mass to be as low as possible. It will handle better in turns, and will work better when offroading.
For these reasons I'm sticking with a 4" lift on my 66.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
