Old 10-19-2012, 10:49 PM   #1
gottwake
gottwake's Avatar
Cutting door top/channel
You guys ever see anyone cut the top of the door to match the bed with the top off, and still be able to use the top? I would think the window would be the same fit all the way to the top yea?
Obviously there would be some door mods to be done.
Pics?
Blazer Project
gottwake is offline   Reply With Quote
Old 10-20-2012, 12:23 AM   #2
heyray
heyray's Avatar
Re: Cutting door top/channel
I never did understand why its like that. I figured they would have lined them up factory?
72 Blazer 4wd
72 Blazer 2wd
69 Blazer 4wd
easy to take apart hard to finish.
Ray of all trades master of none.
heyray is offline   Reply With Quote
Old 10-20-2012, 02:01 AM   #3
gottwake
gottwake's Avatar
Yea...it doesnt look like such a big deal to modify the channel so it can be cut and still have a top.
Blazer Project
Old 10-20-2012, 02:25 PM   #4
DustinU
DustinU's Avatar
What would you do about the wind wing window? Ditch it and go with one larger window?
DustinU is offline   Reply With Quote
Old 10-20-2012, 05:15 PM   #5
hilljob26
hilljob26's Avatar
i think the window slide would show,its fairly close to the top..just something to consider
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 10-20-2012, 09:03 PM   #6
PHAT TONY
PHAT TONY's Avatar
If you did that the window would come right up/out of the door. BUT!!...you could prolly have taller glass cut (it's flat). Hhmmm.....I reckon the door top would need a 1"+ "ledge" to keep geometry to the roof w/strip.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 10-21-2012, 01:32 AM   #7
gottwake
gottwake's Avatar
great points.... I know there is a conversion to go single glass. http://www.youtube.com/user/OnePieceProducts
I suppose what Phat T said is the likely fix for this, make taller glass.
I want to do a roadster again but want to have a chopped and removable hard top.
Blazer Project
Old 10-21-2012, 12:02 PM   #8
PHAT TONY
PHAT TONY's Avatar
As I think about this again....will taller glass fit in the door and be concealed when rolled down? Remove the bottom stop and use power I guess.
1972 K10 4X4-Sold
Old 10-21-2012, 12:41 PM   #9
gottwake
gottwake's Avatar
I thought of that but again, as you stated, if you can modify the arm, it might work. I have an extra door....I will try it on that door and mock up something that might work like electric. I Will keep you informed.
Blazer Project
Old 10-21-2012, 05:38 PM   #10
floyd
Do you have any info(thread link?) on the blazer in the pics? Those are the wheels I want!
I think the door mod would be pretty cool with the wing gone.It would really clean up the lines the step has always looked out of place. Or you could just raise the bedsides and tailgate to match....and chop the top!
floyd is offline   Reply With Quote
Old 10-21-2012, 11:15 PM   #11
gottwake
gottwake's Avatar
Just these...
Blazer Project
Old 10-23-2012, 05:44 AM   #12
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Another cool alternative would be to fab a piece that goes on the bed rail (attaches same as the top) that makes it the same height as the door.
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 10-23-2012, 02:00 PM   #13
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I've seen a few of them cut and most are turned into roadsters without side windows. The one piece windows don't work in the blazers from what I've heard/read because there isn't any support when the window is half way down. Also, you'd have a funny door frame sticking up when you remove the vent window. Cutting them can look odd where the door meets the window frame too. You need to either cut at an angle to match or fab something for the corner. I'd think that putting a modern review mirror in the corner that has a window channel in it would solve the visual and the issue with the window not having support.
I've also seen a few extended bed rails. Most that I've seen are padded or wood. If you add bed rail extensions, you'll have a sudden drop at the tail gate, so you may need to add a tail gate extension too.
Either of these options add challenges to getting a hard top back on. Bed/Tailgate extensions can be removed. If they are removable, they won't have the seamless factory look.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 10-23-2012, 05:25 PM   #14
jaros44sr
jaros44sr's Avatar
If you chop the top, all the glass issues go away, b/c you will have more glass then you need....unless im looking at it wrong
The top of the glass will have to be cut, or you just wont wind the window up all the way. Which is exactly what you want
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-24-2012, 02:30 AM   #15
gottwake
gottwake's Avatar
I think you may be right. The channel can be molded into the wind shield frame and it will seal around that and stock seal of the top. The glass can just be cut down to fit afterwards. IMO. So then the top can be on/off and the door will still look roadster. All the little pieces of the top/door connection are all modifiable IMOP to make the glass fit.
I guess I cant suicide the doors if I do this...oh well.
Blazer Project
