84 GMC 3500- Help with fuel gauge
I had the sending unit in the tank changed as well as the tank itself.
The fuel gauge is still not working. What do I do next? Check the gauge? what else could be wrong? |
Re: 84 GMC 3500- Help with fuel gauge
Gauges are known to go bad. Change it and be amazed
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
My temp gauge & volts gauge work fine but the oil pressure gauge is off.
Since I will have the dash out to change the fuel gauge, I thought about also changing the oil pressure gauge. Are these also known to fail? I know that the oil pressure is fine. The truck is regularly maintained by a mechanic and it runs like a champ. When the timing chain was changed at 108,000 miles, the mechanics asked me what kind of oil i used because they said that the engine looked so clean! |
I have also problems with fuel gauge, I have double tanks, and the gauge shows almost same readings with both tanks, so assuming its not the sending units that are faulty? When the tank is full, gauge shows only half tank, and when the tank is empty, it shows 1/4 and both tanks act the same way. Also oil pressure gauge doesnt work properly. Is the solution to buy new gauges? I also have problems with the illumination of the gauges, I changed all the bulbs, but only few days after half of them are not working.. I guess it has to do with that plastic film that has the wires in it, right?
the plastic "film" (circuit board) could be the problem check the pink wire running from the fuel gauge to the plug on the firwall and all the way back to the fuel sending unit. could be bad, dirty, insulation broken causein the wrong reading. a wire check is simple, costs nothing.
if you replaced the fuel sending unit, do you still have the other one? you could hook the sending unit to the wire, and physically move the float to see the gauge work. or you could shell out the 35 bucks and get a new gauge. its a very simple circuit, shouldnt take very long to narrow it down to the culprit. |
Moderator
![]() Join Date: Oct 2008
You didn't tell us whether the gauge is pinned at 3:00, stuck somewhere else, or just not reading the correct level.
Troubleshooting Fuel Gauge.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 11-18-2012 at 04:06 AM. |
#7 | |||
Moderator
81-90 with gauges without tach is AC Delco part #25044897 $40 US from Amazon. Don't know about international shipping... ![]()
And please let us know if and how your repairs were successful. |
#8 | |
I think it shows only a part of the real oil pressure, engine is fine and only 92K miles, and if the pressure would be that poor, it would have broken up allready. I havent check what the oil pressure really is, but it seems like it works otherwise as it should but shows only a part what it should. It barely moves when the engine is warm, with cold engine it shows the first line.
1987 Chevrolet Scottsdale R10 Diesel "gasoline is for washing your paint brush" |
#9 | |
Moderator
You can check the sender with your digital multimeter. Set it to 100 ohms or the closes scale that's >90ohms. Unplug the sender wire and attach one meter lead in its' place. Start the engine. Touch the other lead to a good ground. If the sender is OK and you really have normal oil pressure you should get a reading between 20 & 80 ohms.
Thanks, will do that and report. We have a great shop here that has almost everything in the storage for these old trucks and other american cars too, they have their own import for the parts, and I think its cheaper to maintain US-made car here than one made in europe..
Thanks again for your time and advice!
