Old 10-20-2012, 07:35 AM   #1
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Factory Tach with LS swap?
My 5.3 harness has a wire labeled "tach"- the instructions was to change the tach to '4 cylinder setting.' I am wondering how others have done this with the 5.3 swap. Mine is an 2003. Thanks
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 10-20-2012, 08:47 AM   #2
chevysrumble
Re: Factory Tach with LS swap?
Digital Dakota makes a tach adapter for this when using a factory style tach. I have read that the settings in the ECM can be adjusted so the factory tach will read correct , but the last ls conversion I did, I never could get my programmer to get it done.
You can only change settings on an aftermarket digital style tach has been my experience.
chevysrumble is offline   Reply With Quote
Old 12-29-2012, 07:16 AM   #3
chuckmc8
chuckmc8's Avatar
Anyone tried the dakota digital product that chevysrumble mentioned? Thanks
Old 12-29-2012, 10:38 AM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
I had waitformeperformance retune my computer to put out a signal for an 8 cylinder tach. Works perfect.
You may be able to find someone local that can reprogram your computer to do the same.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 03-13-2013, 05:23 AM   #5
chuckmc8
chuckmc8's Avatar
Anyone else able to chime in on this who has a 5.3 and factory tach operating?
Old 03-16-2014, 02:24 PM   #6
joeydurango
joeydurango's Avatar
Chuck, what did you end up doing with your factory tach to make it work with your 5.3? Doing the same swap right now and that's about the only instrument I'm not certain on yet.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 03-16-2014, 02:57 PM   #7
69Rumbler
69Rumbler's Avatar
I just went with the VhX it's A really nice up ... Worth the money
1969 C20 CUSTOM "RUMBLEr"
69Rumbler is offline   Reply With Quote
Old 04-12-2014, 03:25 PM   #8
chuckmc8
chuckmc8's Avatar
Update to this thread: I asked the guy who does my programing on pcm to set for 8 cyl tach and it works fine
Old 04-17-2014, 05:11 PM   #9
Toocool
mix up
Toocool is offline   Reply With Quote
Old 04-17-2014, 05:14 PM   #10
Toocool
New Guy I have a 1970 C10 ac 402 /700r4
live in Delaware Ohio
Hi just asking this is a factory tack ? Thinking of putting 6.0, 4l80e
Do you guys have part # for top rad hose! this is good forum for info !
Old 04-18-2014, 07:38 PM   #11
brad_man_72
the boat guy
Welcome to the board.
You may want to check out the ls swap subforum in the engine and drivetrain forum.
I don't know the part number but the factory upper hose from a 99+ v8 silverado fits. It looks like hell so a lot of people swap radiators with both inlets on the pass side.
