Old 10-20-2012, 02:40 PM   #1
windmill
windmill's Avatar
lift cab off frame
how is the best way to lift the cab off the frame,, any pics,, all i have is a cherry picker,,,, and other ways,,,,, i dont have that many buddies,,hahahah.
72 swb pickup
http://i124.photobucket.com/albums/p...k/100_0958.jpg
1967 chevelle ss
1966 mustang getting a l33 ls motor
1969 chevy dump truck
1989 mustang 6.0 ls best time of 1.29 at 5.91
https://www.youtube.com/watch?v=JtbooZoGZmQ
windmill is offline   Reply With Quote
Old 10-20-2012, 04:32 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: lift cab off frame
Do a search for a Cab/bed lift.Someone on this forum has posted a how to on making a jig to do this with a cherry picker engine hoist.Quite a few members have used it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-20-2012, 05:54 PM   #3
Lee H
Lee H's Avatar
We just did this, three times. Three guys, one on each side near the rear and one in front.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 10-20-2012, 06:27 PM   #4
white 67
I made one out of a 4x4 and some 2x6. It works fine and was free.
white 67 is offline   Reply With Quote
Old 10-20-2012, 07:57 PM   #5
Yep. Cherry picker works great.
If you still have the glass in or other stuff it will be very front heavy. You'll need to strap (orange one in my pictureit so it would roll forward. You probably should even have enough lift with yours being a 4x4 (I assume anyways), but you may want to take tiers off and drop it low on jack stands.
I used what I had. Couple 2x4s tie straps, towels and duct tape. It held up great and worked smooth as silk for a 1 man job.
Old 10-20-2012, 10:13 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
4 of us lifted my cab, and it was gutted....no glass or doors.
As for lifting it with the glass still in it....the weight bias is toward the firewall, so you gotta compensate. Pay attention to the pix of the cherry picker and the placement. That was right.
Member Nr. 2770
Old 10-20-2012, 10:18 PM   #7
scotts72heavyhalf
scotts72heavyhalf's Avatar
I just put a strap through the cab, hooked my cherry picker up above the cab and lifted it off, rolled the cherry picker out and set it down, the doors and everything was removed before I did it too. it was really easy, just steady it with your hand when you get it lifted off. Oh and I removed the wheels and tires and had it on jack stands.
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 10-20-2012, 11:28 PM   #8
70CHEVYBB
70CHEVYBB's Avatar
I jacked up my frame, made a jig the bolted to the door hinge area and doors striker plate. I then let the frame down and rolled it out from under the cab. I can now roll the cab around. I belive thre is a pic in my post.
70CHEVYBB is offline   Reply With Quote
Old 10-20-2012, 11:29 PM   #9
67c10rustbuket
67c10rustbuket's Avatar
A couple 2x6s and some 2x4 scraps. copied a design from others here but use 2x6 for overkill. 1 lag bolt to tie the upper together and 1 bolt through the lower extension through the hoist eye (remove the chain). Used a ratchet strap to tie the rig to my engine hoist so I wouldn't have to worry about balancing it. I can get you some measurements if you want. All by myself
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 10-20-2012, 11:48 PM   #10
windmill
windmill's Avatar
i like that send them my way,,, thanks
72 swb pickup
1967 chevelle ss
Old 10-20-2012, 11:53 PM   #11
67c10rustbuket
No prob I will get some measurements and a drawing for you tomorrow.
Dan <---(my name)
Old 10-21-2012, 12:38 AM   #12
benny70
on my truck, me and my brother in law hooked ratchet straps to each corner of the bottom of the cab, put the straps over our shoulders and lifted it off. then my dad pushed the frame out from underneath and we set the cab on sawhorses
benny70 is offline   Reply With Quote
Old 10-21-2012, 06:47 PM   #13
ItsRandy
ItsRandy's Avatar
I used eye bolts screwed into the bolt holes for the fenders and bolt holes for the gas tank, then attached 3 ratchet straps that I hung from the rafters in my garage and lifted at each strap a little at a time.
ItsRandy is offline   Reply With Quote
Old 10-21-2012, 06:57 PM   #14
thelonerife
thelonerife's Avatar
I made a bracket to fit on my picker that holds a 4x4. I can pick it up and move it around easily. I also made one of those cab /bed lifts for my lift but sold it when I was done with a cab move on a project. Both work well.
thelonerife is offline   Reply With Quote
Old 10-21-2012, 10:19 PM   #15
67c10rustbuket
Man there are some other good methods too, I like that eye bolts method from itsRandy. Nice!
Here are some measurements of mine. Note the ** on the left. I had to turn the end 2x6 to clear the hoist as you can see in the second pic above. Also I used a variety of 3 and 4" wood screws depending on how many 2xs I was screwing through. I predrilled all screw holes so the wood would not split. If you have any Qs just let me know. another note if you move the hoist eye position away from you it will move the center of gravity toward you so the cab will tilt toward you as opposed to away from you. Still I used the strap to make sure it didn't tilt away and slip or fall.
EDIT: for some reason the long 2x6 dimension is fuzzy. it is 68" 2x6
Dan <---(my name)
Old 10-22-2012, 02:40 PM   #16
Rogue Willie
Rogue Willie's Avatar
I used chains thru the cab mounting holes and seat belt holes.
69 C-10 in progress
Rogue Willie is offline   Reply With Quote
Old 10-22-2012, 06:47 PM   #17
kamikazekyle05
kamikazekyle05's Avatar
i like that idea rogue willie, ill have to use that
kamikazekyle05 is offline   Reply With Quote
Old 10-23-2012, 08:54 AM   #18
duallyjams
duallyjams's Avatar
Lots of good ideas.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 10-23-2012, 12:41 PM   #19
c10srule
c10srule's Avatar
great idea with the cahains, weve always strapped a 4x4 to the top of our cherry picker, will try the chains next time looks more stable
c10srule is offline   Reply With Quote
Old 10-23-2012, 03:35 PM   #20
Wasted Income
Boosted Member
Wasted Income's Avatar
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
