Old 10-20-2012, 03:37 PM   #1
vjjack04
vjjack04's Avatar
wilwood prop valve issues
Folks,
My proportioning valve is not letting fluid go to the rear brakes. It seemed to be working when i first put it in, but not now. I took it apart but can't be sure if it is working.....I have fluid to the "in" from the master cylinder but the valve seems to be going bad....anyone experience this?
vjjack04 is offline   Reply With Quote
Old 10-20-2012, 08:01 PM   #2
solidaxel
solidaxel's Avatar
Re: wilwood prop valve issues
The way i solved this problem I plugged one half of the M/C and worked on one end at a time by bleeding the wheels until I had a good pedel and fluid.
I then hooked up the other half and bled that end until I had good pedel and no more air.
Get a good helper and another quart of fluid, you can do it !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-20-2012, 09:42 PM   #3
vjjack04
vjjack04's Avatar
Thanks, but I think having the brake system together for a year with no fluid, dry rotted the inner seal.....I took it apart and it seemed to have issues. Once I blew out the housing and got the seal moving it worked better and I had brakes....however, I am going to get a new prop valve just to ensure things are ok......this is/was annoying....I do appreciate you response though...
