Old 10-20-2012, 04:35 PM   #1
esbstuff
Drum to Disk Brake Swap? 87-08
I have a 87 ton truck with drum brakes and have a 08 ton rearend with disk brakes. Will all the disk stuff bolt up to the 87 drum rearend?
I realize there will be brakeline and e-brake cable issues, but I am wanting to know if the 'hard parts' will bolt up.
Thanks Eric
esbstuff is offline   Reply With Quote
Old 10-20-2012, 09:30 PM   #2
andrewmp6
Re: Drum to Disk Brake Swap? 87-08
I don't think it would work the 99 up trucks didn't have a 5 lug and i believe the 6 lug is different too.Look on the vendors on here a few sell a rear disc kit pretty cheap.
andrewmp6 is offline   Reply With Quote
Old 10-21-2012, 08:35 AM   #3
esbstuff
So what does this have to do with a ton truck?
Old 10-21-2012, 05:30 PM   #4
Mr. 250r
Mr. 250r's Avatar
I the flange that bolts it to the axle housing is different im pretty sure
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC LB DRW - Sold
2003 1500 Silverado - Selling
2004 Ram 3500 5.9 H.O NV56 CC LB DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LB SRW
Mr. 250r is offline   Reply With Quote
Old 10-21-2012, 08:15 PM   #5
ghettoluxury
ghettoluxury's Avatar
No, it will not bolt up the backing plates are not the same. I swapped the conplete rear axle from a 04 into my 73. just had to grind the spring pads off and reweld them in the new spot.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 10-22-2012, 12:20 AM   #6
Mr. 250r
Mr. 250r's Avatar
Also pretty sure the axles are exactly 3in wider or 1.5in on each side which for some reason people have a problem with but i can't tell the difference when i swapped out my semi floater for an 05 FF
