Old 10-20-2012, 07:29 PM   #1
clemsonteg
Disc brake conversion - master cylinder
I was looking at the ECE brake conversion for my 70 c10. I noticed it comes with a new dal pot master cylinder, proportioning valve and a new line that needs to be bent. I seem to have all those parts already so do I have to replace them? Is there something different about those parts made specifically for disc brakes? Below is a picture of my current setup.
clemsonteg is offline   Reply With Quote
Old 10-20-2012, 07:33 PM   #2
shawno72
C/10 junkie
shawno72's Avatar
Re: Disc brake conversion - master cylinder
That is not a proportioning valve, its just a distribution block so you will need the prop valve.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 10-20-2012, 07:40 PM   #3
GMCJOE
GMCJOE's Avatar
not knocking ECE, but check out GMCPauls also. They have a pretty good deal on there brake conversion kits. The proportioning valve is different (disc/drum). From research I have done, there are different M/C's for power and non power. And I also believe the lines are different from when I was looking thru LMC's parts catalog. I bought a complete setup from a member here on the forum. All the lines, M/C, brake booster, and pedal setup.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 10-20-2012, 10:44 PM   #4
jocko
jocko's Avatar
what year is your truck? If pre-71, you'll need the master cylinder, prop valve, and new lines - the disk/drum master normally has different size reservoirs and the prop valve has a job to do between disk/drum setup. If you happen to have an early 71 that still has dual drum, then will need it all for that as well. Disks were supposed to be an option on 71's (reference the disk brake option sticker on 71 tailgates) but I'd swear they became standard by the end of the year (can't prove it, just a theory). Also, front/rear brake line size is normally different between disk and drum. So, I'd go for the whole kit. I've never had a problem with ECE or POL. CCP has good stuff, but have heard a few folks complain on here about it. But I think there is a rep on the board.
