Old 10-20-2012, 08:41 PM   #1
Rickey
Rickey's Avatar
need help
Just got a 72 blazer today and it has a 4 speed manual, what do I need to change it to a 700R4 or turbo 350.
Rickey is offline   Reply With Quote
Old 10-20-2012, 08:57 PM   #2
longbed67
longbed67's Avatar
Re: need help
Need some more info... Which engine? What are you plans with the vehicle? Power wise? Carb? FI? ect.... You will need a flex plate, torque converter, trans, different trans mount, and kick down linkage for starters.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 10-20-2012, 09:35 PM   #3
Rickey
Rickey's Avatar
Re: need help
The blazer has a 350 engine, elderbrock carb. I know I need a automatic shift column, linkage, kickdown. What I don't know is what tranny do I need my truck is 4 wheel drive.
Old 10-20-2012, 11:06 PM   #4
beonkey
Re: need help
Rickey
You need the th350 short tail and 205 transfer case, I happen to have both that will be for sale here in CA. I actually did this swap from a manual to auto. I stressed about it for too long and it was super simple and straight forward. I bought a tilt auto shift column and new Trans and t case, hi hump with only t case hole and shift linkage. Let me know if you know someone in Cali headed your way!
Torque converter
Flex plate
Starter
Kick down cable
Trans cooler lines
I changed radiators to a four core with cooler line inlets, but you could do an external Trans cooler for cheap.
As far as Trans mount, I used my original as it is the tease that is on the mount.
Of course you can always go a different route like 700r4 Trans
beonkey is offline   Reply With Quote
Old 10-21-2012, 02:08 AM   #5
roOstersan
roOstersan's Avatar
Re: need help
Originally Posted by beonkey View Post
Rickey
Torque converter
Flex plate
Starter
Kick down cable
Trans cooler lines
Hey beonkey, what tilt column did you buy? How was the quality? And how much did you spend? Very interested! Did it fit well in the k5?
Thanx for the help!
roOstersan is offline   Reply With Quote
Old 10-21-2012, 09:54 AM   #6
4oldcars
4oldcars's Avatar
Re: need help
Good tech article in the December Ho Rod magazine with all your answers
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 10-21-2012, 10:55 AM   #7
beonkey
Re: need help
Thanx for the help!
Hi
I bought a rebuilt van tilt, so it is about 1.5" shorter which gives me more room. It was ready to bolt in and came with intermediate shaft as well. I really like it and its good quality. I met this guy at Pomona swap meet out near me and he shipped it to me when completed. The company name is steering column pros
Steeringcolumnpros.com
Old 10-23-2012, 10:51 PM   #8
roOstersan
roOstersan's Avatar
Re: need help
Good stuff... Thanx for the info!
