10-20-2012, 09:33 PM | #1 |
need help 250-350 swap clutch?!?!
Fired my motor today only to find I couldnt get my clutch to disengage! Everything outside (linkage) appears to work properly and I'm certain it's traveling far enough but still doesn't disengage. It's a 250 flywheel on a 350, with a four speed (3+granny). I believe I'm running a 350 clutch setup and I'm beginning to think this is my problem. Was I supposed to use the 250 clutch setup. Please any help is appreciated I'm doing this truck for a friend and feel terrible it's not drivable yet!
Posted via Mobile Device |
10-20-2012, 09:38 PM | #2 |
Re: need help 250-350 swap clutch?!?!
umm which 250 flywheel do you have? and which clutch and which trans, and which shaft (imput spline and diameter) out of the trans...
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
10-20-2012, 09:41 PM | #3 |
Member #1049
The flywheels are the same between the two, It sounds like you may have the incorrect throw out bearing for the pressure plate you are using, there are two types of pressure plates the diaphram style and the three fingered style.. necessitating two different bearings, a long one and a short one.
10-20-2012, 09:45 PM | #4 |
The throwout bearing came with the clutch kit... do still think that could be the issue. I was unaware there were two different 250 flywheel.... I just ordered a clutch the same diameter but the 350 version from Napa
10-20-2012, 09:53 PM | #5 | |
10-20-2012, 10:07 PM | #6 |
I must have the 11" since the 350 version appeared to be the same diameter and it bolted up?
10-20-2012, 10:18 PM | #7 |
Highly likely, but not guaranteed.
10-20-2012, 10:51 PM | #8 |
I'm using a 11" diaphram style for the 350. I was just hoping someone else had done a 250 to 350 swap and used the stock manual trans. Possibly remembering which clutch they used with it.
10-20-2012, 11:34 PM | #9 |
I am going to have to go with what livrat said and say that you have the wrong throwout bearing... Is this a new clutch? and was it a kit or something you pieced together?
10-21-2012, 06:07 AM | #10 |
Kit from Napa. Like I said though it's the 350 version. It has a different part number from the 250.
10-21-2012, 10:04 AM | #11 |
I am a Referee of life.
It's been a while since I did a clutch in one but IIRC the 350 style throwout bearing is the short one while the 250 is longer.The clutch linkage wouldn't move the throwout bearing far enough to disengage.Keep in mind that that is from my memory which is loaded with "Senior Moments" and "Brain Farts"
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-21-2012, 11:05 AM | #12 |
I'm thinking the same thing... Thank you guys I'll keep everyone updated after I switch it next week.
11-07-2013, 03:19 AM | #13 |
Sorry it's been so long forgot to come back and update you guys.... The bushing was just super tight! Started it up in gear hit the gas and pushed in the clutch, did that in forward and reverse a couple times and it freed if right up
