10-20-2012, 10:59 PM | #1 |
Emergency
I broke down on th I broke down on the road and no one will help me. all lights massive back fireing and won't start the battery the week old new alternator and new voltage regulator. Any ideas an and grammar on phone in th on phone in the dark .
just like that old Johnny Cash song. "One piece at a time and I am go na make an old C10 mine a look at all your faces when I drive through your town" |
10-20-2012, 11:05 PM | #2 |
Re: Emergency
Kinda sounds like a timing issue. Was it running good before it broke down? HEI or points ignition?
1979 Silverado C10 Shortbox - Photo Album 1977 Silverado K20 Camper Special - Photo Album 1972 C10 Custom Deluxe Highlander - sold 1971 Cheyenne Super Longhorn -sold 1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb. 1970 Chevy C10 SWB "Sprout" -sold 1972 Cheyenne K20 -sold 1969 GMC Shortbox Stepside 4x4 -sold 1972 GMC Jimmy 4x4 -sold |
10-20-2012, 11:08 PM | #3 |
Re: Emergency
Points ignition, I had a slight miss fire when I left ,but I have 4 champion and 4 auto light plugs in
10-20-2012, 11:09 PM | #4 |
Re: Emergency
any lights working?
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
10-20-2012, 11:10 PM | #5 |
Re: Emergency
Sorry for grammar talk to texts sucks Posted via Mobile Device
10-20-2012, 11:12 PM | #6 |
Re: Emergency
Lights just came on but not enough power to start. I get a cranking sound and the dash brake light to come on
10-20-2012, 11:15 PM | #7 |
Re: Emergency
You didn't get any water some how on the distributor? Mine acted like that after I washed out the engine compartment and all I had to do is remove the distributor cap, take a paper towel and dry it out. After I did that it fired right up.
10-20-2012, 11:18 PM | #8 |
Re: Emergency
Last time I fought an issue like this it was a combination of incorrect plug gaps and the timing being way off on a truck I'd just bought. Unless the retainer bolt is loose, I doubt your timing just changed while driving it. If you've been cranking it for very long to try to get it started, the battery may be too low now as well.
10-20-2012, 11:48 PM | #9 |
Re: Emergency
So what exactly happened? Were you just driving along and it quit? Or do you go someplace and now it won't start to leave? Was it an active failure like a bang or pop then quit or maybe a sputter down? Are the plug wires secure at the plugs?
Had a total beater timing chain jump in stop and go traffic.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
10-21-2012, 12:08 AM | #10 |
Re: Emergency
When I left my mother's,house I had a slight miss fire at about 1500 rpm. As I was driving I went to use my turn signals and nothing happend. While coasting I put the truck in N and revved it and did not have turn signals still. As i continued driving th lights got dimmer and dimmer. If I shut the lights off it would stop back firing. At this point the engine was missing in all rpms and the light we really dime. As I was going to a red light it just shut down. I am having it towed to my buudys shop since I don't have time to work on it as I am at my dads and I leave for my mothers tomorrow night.
10-21-2012, 12:27 AM | #11 |
Re: Emergency
Could be a problem with the voltage regulator or alternator? Sounds like it was only partially charging and you were gradually draining the battery down until you didn't have enough spark to fire at the plugs.
10-21-2012, 12:45 AM | #12 |
Re: Emergency
This week I installed a reman alternator and a cheap voltage regulator I found a ground not hooked up could that cause it its the green wire
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
10-21-2012, 12:45 AM | #13 |
Re: Emergency
concur - bad alt would be my guess, no charge to batt. symptoms sound like it's dead. A jump might get you home if someone will stop. If you can get it running (after a jump) - if a screwdriver or something metal will attract to the back center of the alternator, that's a good sign. If no magnetic pull, alternator (and/or volt reg) on the fritz. Can you call a tow truck? 411 for a tow?
10-21-2012, 12:50 AM | #14 | |
Msgt USAF Ret
Re: Emergency
If you need to replace the alternator then get a 12 SI internal voltage regulator alternator and eliminate the old external regulator. Even if the battery is bad the alternator should have kept the engine and lights running.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
10-21-2012, 12:52 AM | #15 |
Re: Emergency
if you're referring to the chassis ground that is bolted to the firewall, no - that's probably not your problem, but if you have a screwdriver, screw it to something.
Voltage regulator should have the following: Red wire goes to alternator "B" terminal Purple (or blue) wire goes to alternator "F" terminal White wire goes to alternator "R" terminal Brown wire goes to firewall fues block plug Altarnator should have the following: the 3 things noted above + black (or any color) should go to ground. Also, the red wire that goes to the voltage reg also should go to the battery Probably not much help at 1150pm - hope you have a flashlight. Standing by... Last edited by jocko; 10-21-2012 at 01:24 AM. |
10-21-2012, 12:53 AM | #16 |
Re: Emergency
Btw, u never asnwered the rain question - have you hit any water? Heavy rain?
If yes - possibly a bad distributor cap - hairline cracked, etc. |
10-21-2012, 12:55 AM | #17 |
Re: Emergency
My dad drove me home, we tried jumping it but it would not work. I drifted it to a funeral home .
10-21-2012, 12:56 AM | #18 |
Re: Emergency
No rain but maybe a crack in the distributor
10-21-2012, 01:17 AM | #19 |
Msgt USAF Ret
Re: Emergency
Your regulator is mounted on little rubber washers and needs to be grounded to the radiator shroud and also to the back of the alternator for it to work correctly. The green wire might have done this but usually a black wire is used for the ground wire. Those little electrons don't really care what coat they're wearing.
Alternator ground. regulator mount. The small wire on the right edge is the ground. Here is the electrical diagram. The ground wire is on the left edge of the diagram and runs to the bottom and back up to the alternator.
10-21-2012, 03:58 AM | #20 |
Re: Emergency
I couldn't help but thinking after reading this post. Where else is a guy going to turn to at 12:00 midnight for help when he is broke down and stranded and have the best of the best mechanical and electrical gurus answer your call for help at no charge at all. That's why I've enjoyed this site from day one. Nice work guys
Scott |
10-23-2012, 12:37 AM | #21 |
Re: Emergency
Getting anywhere with your electrical gremlins?
10-23-2012, 08:55 AM | #22 |
I am a Referee of life.
Re: Emergency
Don't forget,there is a hotline for help.It's run by the BB and staffed by whoever is close and can help.Members have been helped in many ways.One military member even had some fellow BB members help with an engine swap and getting him back on the road to keep him from beoing late to his post.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-23-2012, 09:08 AM | #23 | |
Re: Emergency
__________________ Rob '72 Chevy C-10 - 350-5.7/TH350/PS/PB/AC Build Thread - http://67-72chevytrucks.com/vboard/s...87#post5503187 Semper Fi and Gig'em Aggies! |
10-23-2012, 04:26 PM | #24 |
Re: Emergency
Thanks for the help, I got the battery charged and had another guy look at it (see what I missed) and it looks like the black ground wire is gone in the pic VetteVet posted. when I was talking to the one guy he asked if I had to polarize the system. I said I did not know. Do I need to polarize the system
Also I wanted to thank all of you for your help, Once I get my truck running I am defiantly becoming a paying board member
10-23-2012, 04:28 PM | #25 |
Re: Emergency
also when we change the voltage reulator insted of using the rubber thing we used a bolts with washers and nuts. Should I have used the rubber things
