Old 05-30-2003, 10:40 PM   #1
da-burb
"Ochre Ogre"
da-burb's Avatar
1996 G30 1 ton GMC Van 6.5 Diesel
This just came to me 2 days ago. It is a 96 1 ton van with under 100,000 miles. The insurance company totalled it after a wire harness meltdown under the dash. It was $3000 to replace!!!! A few parts have been lifted from it and almost everything else is available with the exception of the OD 4L80E and the rear heater. The diesel is supposed to run just like it should. I don't know if it would start with a battery in there or not. I don't even know if the key or ignition switch is still in there. It did drive in to my mechanic's shop. The previous owner had paid $7500 for it in 2002.
If you see something that you are interested in email me @ da-burb
More pictures @
1996 G30 GMC Panel Van
Price $1200/bo or by the piece
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 05-30-2003, 10:58 PM   #2
68 Suburban
68 Suburban's Avatar
Is that a computer controlled diesel engine?
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-30-2003, 11:00 PM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
Yes it is, and that wasn't damaged in the melt-down either.
Old 05-31-2003, 05:54 PM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
Hey 68, I just read that you want 20mpg but not without your TH400. That is why I am keeping the transmision in this van. It is the 4L80e which is the modern TH400 with OD. Because it is a diesel it has a stand alone computer that controls the shifts and lockup. If it was from a gas engine the computer is part of the engine computer and you would have lot's of $$'s to make it work. This is supposed to be a bolt in project. I will soon find out.
Old 06-01-2003, 08:26 AM   #5
68 Suburban
I had that same trans set up in a 92 1 ton I had. It was a nice set up.
Old 06-02-2003, 08:46 AM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
ttt
Old 06-03-2003, 09:39 AM   #7
da-burb
"Ochre Ogre"
da-burb's Avatar
ttt
Old 06-06-2003, 05:09 PM   #8
da-burb
"Ochre Ogre"
da-burb's Avatar
ttt
Old 06-07-2003, 12:35 AM   #9
69oldie
Never too many LONGHORNS!
69oldie's Avatar
da-burb,
Just a question...........wouldn't that set up (4L80E stand-alone from a diesel mated to a gas motor) shift at incorrect times? The reason I ask this is diesel engines have the "power range" at much lower rpms then gas engines. What this causes is shifting much too soon for gas engines. Can these factory stand alones be re-programed for differen shift points??
Just a thought.....
69oldie is offline   Reply With Quote
Old 06-07-2003, 01:26 AM   #10
dtlilly
dtlilly's Avatar
Not intending to step on any ones toes, but I believe the tranny can be re-programmed to whatever shift points you desire.
dtlilly is offline   Reply With Quote
Old 06-10-2003, 08:26 PM   #11
da-burb
"Ochre Ogre"
da-burb's Avatar
ttt
