10-21-2012, 12:34 PM | #1 |
Old member
Angled Dashes
Does anyone know of a aftermarket dash that is angled up to see better. I want to either buy one for my guages are make one I guess out of a old glove box.
Has anybody done this are know of anything out there that would work.Thanks
10-21-2012, 12:56 PM | #2 |
Re: Angled Dashes
I've never seen one but it would be fairly easy to make a wedged shaped spacer to mount under your present dash.
http://smg.photobucket.com/albums/v655/aaronhero/ |
10-21-2012, 01:59 PM | #3 |
Old member
Re: Angled Dashes
I have thought about that. I'm just seeing what is out there first. That maybe what I try and see if it is what I want. I think a little angle to the guages would help a lot of people seeing them better. I know it would me.
10-21-2012, 02:26 PM | #4 |
Re: Angled Dashes
interesting idea, but I'd also be very concerned about angling it up and then inadvertently making the windshield glare off the plastic gauge faces a problem. But, of course, you could experiment to make sure that didn't happen before you started hacking.
10-21-2012, 03:00 PM | #5 |
Old member
Re: Angled Dashes
I don't think I would angle it that much but yes that would have to be a factor in it also. I think the dash pad would keep the glare off the dash tough.
10-21-2012, 03:30 PM | #6 |
bbadfred
Re: Angled Dashes
autometer makes angle rings for both 2 1/16 and 2 5/8 gauges if you are using non stock gauges.
10-21-2012, 03:49 PM | #7 |
I am a Referee of life.
Re: Angled Dashes
Andy,you might pull the screws from the bezel and put 2-3 washers behnd the bottom with the screws put back in thru them.If it does what you want then an angled spacer shouldnt be hard to make.If it doesn't work,you only out the time and $1.00 worth of washers you can reuse.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-21-2012, 04:04 PM | #8 | |
Old member
Re: Angled Dashes
PanelDeland, yea I'm going to play with it and see.
10-21-2012, 04:29 PM | #9 |
Re: Angled Dashes
Go to a custom boat shop. Boat shops sell many different angled bezels. My 68 Chevelle has a full custom dash my buddy cut out on a lazer cutter. I had to buy these bezels because, the angle on a 68 Chevelle's dash slopes downward. I will see if I can upload a picture of it. Sorry if you really can't see anything. I'm working out of the country and can't get a better pictures. Also, since thus photo was taken i was able to get some *****in anodized blue billet cup holders from the boat guys too.
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
10-21-2012, 04:35 PM | #10 | |
Old member
Re: Angled Dashes
10-21-2012, 05:11 PM | #11 |
Re: Angled Dashes
heres what i built from a glovebox door
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
10-21-2012, 05:26 PM | #12 |
bbadfred
Re: Angled Dashes
10-21-2012, 05:27 PM | #13 | |
bbadfred
Re: Angled Dashes
try this
10-21-2012, 05:33 PM | #14 |
Old member
Re: Angled Dashes
Thanks will call about them also.
10-21-2012, 05:38 PM | #15 |
Old member
Re: Angled Dashes
That is sweet right there! I wished my welding skill was that good.
