Yepper about 40-50 hours in it but it works. Totally awesome. Will take some pics on sunday. of the install/ mods. This mod is not for the faint of heart. Just thought I would let you know.:p :p
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
sweet, u have any pics? how did you finally get it to work?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
KEEP ON TRUCKING
congrats waitin for pics
72 cheyenne 2wd lwb 71 k20 sons bassett va |
Ditto on the wait for pics...aren't you glad you stuck with it??
69 GMC K10 ..some restoration required....still.. ![]() |
![]() Join Date: Aug 2001
just like the old saying - never give up...on a custom mod!
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
![]() Join Date: Apr 2003
great, show us some pics and the quick run down. I could never get mine to work right.
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
I used a cabinet hinge from our Home Depot. I need a pair of LED's to complete it . I had to cut the entire stake pocket out behind where the light goes. and cut 1/16" (the thickness of the cutting disk) out from under the light and weld the piece back in place. flip the tail light housing so that the bulb is at the bottom of the box side. I needed to mount the hinge there, and also keeps the amount of stress on the wires down. Oh I needed to sand the lip on the lens down a bit just a basic recontour so that it would not hit ther bottom of the box side when opening. I used 120 paper on a block the 400 the 2000 the polishing compound. looks perfect.
I am happy that I did not give up.
Have A Nice Day!
Sounds like a good idea! Would like to see pics.
1970 CST K10 350/350/205
Short Bed - Fleetside Tach-Tilt-A/C-Tow Hooks Front & Rear Disc Brakes Front & Rear Posi 3.73 Gears 30 Gallon Stainless Fuel Tank SOLD 01/18 !!!!! 2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ ![]() ![]() |
