Old 10-21-2012, 03:19 PM   #1
J Lee
J Lee's Avatar
Fuel pump losing prime
my 79 blazer has had this problem ever since I bought it. It had been sitting for a while when I bought it but you could fill the carb bowls with gas a couple times and it would prime up and run but would lose prime if allowed to sit overnight. I assumed this was due to the junk Edelbrock carb that was on it and the fuel pump going bad. I have now changed the carb to a new 600cfm Holley and replaced the fuel pump but the problem is still there. once it is primed in the manner described above it is fine and will run and will crank again after sitting a short period but the pump is still loseing prime if it sits overnight. All the lines are tight and it is not leaking gas anywhere so I can't figure out what could be causing it now. any help would be greatly appreciated.
Jeff Lee
J Lee is offline   Reply With Quote
Old 10-21-2012, 08:25 PM   #2
AsianBlazer
Active Member
AsianBlazer's Avatar
Re: Fuel pump losing prime
Jeff,
Check your fuel line hose running from the tank to the pump, it may have cracks in the hose small enough you don't catch with a quick visual, but enough to cause fuel not to pull from the tank consistently. I had the same issue with mine, drove me crazy, turned out to be old, cracked hose from the tank to pump, after I had replaced the entire fuel system. Good luck with that.
Mike
AsianBlazer is offline   Reply With Quote
Old 10-21-2012, 08:29 PM   #3
1955 mancave
1955 mancave's Avatar
Originally Posted by AsianBlazer View Post
Jeff,
Mike
X2 i also had the same issue and also had to replace every bit of hose.
1955 mancave is offline   Reply With Quote
Old 10-21-2012, 08:42 PM   #4
68Timber
I know the pieces fit
68Timber's Avatar
My 79 was doing the same thing, it was cracked hose at the pump.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-21-2012, 08:58 PM   #5
kwin
kwin's Avatar
My suburbans all had detorated fuel pump hoses, one had turned to jelly, two had cracked up, the two with cracks would start if you primed the carb, but would not fire after sitting.
Keith Winsor
www.ramsaywinsor.com
kwin is offline   Reply With Quote
Old 10-21-2012, 09:22 PM   #6
J Lee
J Lee's Avatar
Ok I will try the hoses and let ya know in a couple days.
Old 10-24-2012, 06:22 PM   #7
J Lee
J Lee's Avatar
Problem solved! I changed out the lines from the tank to the pump and also the lines from the pump to the carb re-primed it and today after 2 days of not being cranked it fired off with just a few pumps of the accelerator. Thanks for the help. As a side note the main rubber fuel line from the tank to the pump literally crumbled in my hand when I was removing it from the hard line on the frame.
Jeff Lee
