Old 10-21-2012, 05:43 PM   #1
The Big Green
67 bagged and want a 5.3, but need help!
I have a 67 laying body on 22/24, 2.5in Z, 350/400t, and so on. I really like the idea of a possible 20mpg average so thought Id 5.3 it. Ive got leads on 2004ish 5.3 auto trans for $1400. I have 73-87 frame mounts and a custom 3spd 350/400t tranny mount, tranny tunnels raised. What parts do I need to drop it in and get it mounted besides trimming the frame? Will the tranny and oil pan clear easily on a bagged 67-72?
The Big Green is offline   Reply With Quote
Old 10-22-2012, 01:02 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 67 bagged and want a 5.3, but need help!
adapter plates for the motor mounts, drill new holes and move trans mount to new spot (depending on where engine sits), wiring harness, pcm, tac and pedal IF its dbw, driveshaft cut to length, any misc sensors that were damaged or not working, fuel pump (possibly new tank depending on choice of pump and current tank style).
Thats a start, but there are things like gauges, shifter etc that may need work depending on what parts you choose.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-22-2012, 02:54 PM   #3
The Big Green
Well I found a setup I think. I hope I can do this swap.
Old 10-22-2012, 08:50 PM   #4
The Big Green
Backed out, it was a 2002 with 197,000 miles.
Old 10-23-2012, 12:51 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
probably a good idea, that guy was smoking freebase if he thinks its worth that.
car-part dot com
you can't not find one on there prob 1/2 of us have sourced them on there.
side note....the freebase thing was a weird reference, too many 80's movies this weekend I guess...
Old 10-23-2012, 12:54 AM   #6
BrutonLS1
BrutonLS1's Avatar
Motor adapter plates are pricey. I built my own, I can give you the measurements if you want.
BrutonLS1 is offline   Reply With Quote
Old 10-23-2012, 06:49 AM   #7
The Big Green
Thats a salvage yard, said they may get another tomorrow or it may be a while it depends. He thought it had had 135,000 which isnt too bad. He said theres a month warranty but I can hear it before they pull it. Said $1100 if it had had the 135,000 on the 2002.
Old 10-23-2012, 09:16 AM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
IF it were me, I would get a newer motor and throw the DBC intake on it( if that is what you want), also call LKQ, that is where I bought my motor from. I got a 4.8 with 7K miles for under 600. it has plenty of power for me and it gets good MPG.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-23-2012, 09:28 AM   #9
The Big Green
LKQ?
Old 10-23-2012, 09:54 AM   #10
Clyde65
Clyde65's Avatar
yep there is one near you I am sure. LKQ.com
Clyde65
Rebuild of Clyde
support our troops!
Old 10-23-2012, 09:58 AM   #11
Clyde65
Clyde65's Avatar
they have one in Fayetteville.
5.3's 1000-1250.
4.8's 900
6.0's 12-1500
Clyde65
Rebuild of Clyde
support our troops!
Old 10-23-2012, 11:15 AM   #12
The Big Green
Its not showing any but you have to search a specific year and model. Are the prices you posted engines only for sale or everything?
Old 10-23-2012, 11:47 AM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
imo he's still asking too much for it.
Besides at 135k its not the engine that I'm worried about....it probably has a 4l60e behind it, which at that high mileage doesn't exactly have much life in front of it when put behind a v8 in a performance car.
I just blew up another 4l60e....in a freaking 4.3 blazer...
Old 10-23-2012, 12:07 PM   #14
The Big Green
The more I sit and think the more I like the fresh rebiult 350/400t thats in it, basically I wanted the 20ish mpg the 5.3 may get over my stock 350's 13mpg lol.
Old 10-24-2012, 09:39 PM   #15
The Big Green
Well cant find my engine anywhere. Im going to keep my 350 and cam it up and put taller than 4.11 gears. I should get decent mileage I hope.
Old 10-25-2012, 08:22 AM   #16
Clyde65
Clyde65's Avatar
Consider Puting a 700 or 200 4 speed tranny, keep the 3.73's and you can get better mileage then. Or throw aftermarket EFI on your 350 with the 4speed auto.
Clyde65
Rebuild of Clyde
support our troops!
Old 10-25-2012, 08:24 AM   #17
Clyde65
Clyde65's Avatar
Also the prices I showed we're for a 2005 only the motor. You can call them and see what they will do for and entire pull out. If it were me, I would go for a 04-07obs and under 50k.
Clyde65
Rebuild of Clyde
support our troops!
Old 10-25-2012, 12:48 PM   #18
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I've got a cheap used 200-4r if you decide to go that way.
Needs freshening up is all.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-25-2012, 01:38 PM   #19
The Big Green
I searched LKQ, Bayless in Springfield and they have nothing in a complete swap. He said call tomorrow because theyre going to an auction and may come across something. Its not that I dont want to try a 5.3 but maybe its a sign becuase I cant find one anywhere.
Old 10-25-2012, 02:11 PM   #20
Clyde65
Clyde65's Avatar
did you look at Tahoes and Suburbans also not just trucks?
Since you called them, they might not. most recyclers pull the motors and trannys with low mileage and rack them to sell them as replacements.
Clyde65
Rebuild of Clyde
support our troops!
Old 10-25-2012, 07:50 PM   #21
The Big Green
I searched them all, but when I called I said any year 5.3.
Ok I need help lol. I got a friend with a 2002 Tahoe wrecked(bodyless), 5.3 4wd setup with 82,000 miles. I got him from $1400 to 1250 for engine to tcase or 2100 to $1750 for the roller 4x4 no body. I then asked if I came with $1100 if hed ask me to leave. He said he would do $1100 and sell it with a 2wd tranny. Im wanting to jump on it but should I or should I keep looking?
Old 10-25-2012, 08:30 PM   #22
Crash_OK
Crash_OK's Avatar
Does that include all the acc., wiring harness, etc.. if so sounds like a good deal to me.. I gave $1500 from mine.. 2005 DBW 80000 miles.. Engine, trans, acc., wiring harness.. everything I needed..
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 10-25-2012, 08:31 PM   #23
Crash_OK
Crash_OK's Avatar
If you want PM me and I will give you a contact in Tulsa that can fix you up..
Mark
Crash's 69 4x4 SWB
Old 10-25-2012, 08:50 PM   #24
The Big Green
Yes its everything for $1100 and its 5miles away from me. Tulsa? I emailed B&R Salvage a few mins ago, said to have long blocks for $500 and ecm and harnesses for $200.
Old 10-25-2012, 09:17 PM   #25
Crash_OK
Crash_OK's Avatar
The one close to your house sounds like a good deal.. however if it doesn't work out email Tanner at brautoparts@gmail.com. Tell him that Mark gave you his name and e-mail. He treated me right on more than one deal. Good luck...
Mark
Crash's 69 4x4 SWB
