Old 10-21-2012, 08:41 PM   #1
erikh09
2 questions to help me get back on the road
Hi all,
I have 2 questions I hope I can get some help with:
1. I swapped the v-6 out of my 67 GMC for a 350. I am curious as to what other members used for a lower radiator hose. My radiator has a near 90 degree bent in the outlet so finding a hose to run from there to the water pump has proved to be tricky. I tried flex hose but it kinks at the water pump inlet. Any thoughts...
2. Anyone ever seen a tailshaft housing for a turbo 400 trans without the connection for the speedometer cable? I got mine all bolted in and ready to go and of couse that is when I realized it! There is NOWHERE to plug the speedo cable in! Are these tailshaft housings readily available somewhere? The 2 junkyards near me did not have them.
Getting frustraded because these 2 minor inconveniences have held me up from getting the truck on the road...
Thanks all
erikh09 is offline   Reply With Quote
Old 10-21-2012, 09:10 PM   #2
hayhauler71
hayhauler71's Avatar
Re: 2 questions to help me get back on the road
Look for a lower radiator hose for a 71 c 10 with a 350
Check your local trans shop for a used tail shaft housing are you sure the hole just does not have a plug in it?
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 10-21-2012, 10:04 PM   #3
Hubscrub
Cruzin
Hubscrub's Avatar
is this the type you need? Gates #20694
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 10-21-2012, 10:34 PM   #4
erikh09
hubscrub,
Does the outlet for the lower hose on your radiator bend up to a 90 degree or is it straight?
Old 10-22-2012, 05:03 PM   #5
Hubscrub
Cruzin
Hubscrub's Avatar
I think it turns up at a 45°, cant remember
Proverbs 3:5,6
Old 10-22-2012, 07:18 PM   #6
16N67
16N67's Avatar
The speedometer goes into the left rear side of the main transmission case, not into the tail housing. It could have a soft plug in the hole if it was a 4 wheel drive transmission.its almost a 2" hole, there should be a steel gear pressed onto the tail shaft just behind the governor gear.
16N67 is offline   Reply With Quote
Old 10-22-2012, 09:05 PM   #7
erikh09
It does appear mine has a plug in the hole (almost looks like a freeze plug?). Once I remove that I presume there is some type of adapter or insert I will need to get in order to connect the speedo cable correctly?
Old 10-22-2012, 09:26 PM   #8
16N67
16N67's Avatar
There are two different adapters depending on what speedometer driven gears you are using. One is for 36 through 39 tooth driven gear and one is for 40 through 43 tooth.
Old 10-22-2012, 09:54 PM   #9
16N67
16N67's Avatar
Here is a picture
Old 10-22-2012, 11:02 PM   #10
erikh09
16N67,
Once I get the plug out, how do I determine which adapter I need? Are they readily available somewhere?
Thanks again!
Old 10-23-2012, 09:52 AM   #11
16N67
16N67's Avatar
Some are still available from GM, and aftermarket transmission part supplier's. You need to know what rear end gears you have to determine what speedometer gears you will need. Some of the newer 400's had plastic drive gears, instead of steel, that are held on with a clip, easier to change.
