Old 10-21-2012, 11:09 PM   #1
elvisp
How to change a 86 silverado odometer?
I have a 1986 silverado with a broken odometer. i picked up a used one. Can anyone give me some tips on how to replace it without messing up the selector Drive/Neutral/revers column. Any advice would be great. Thanks. email kpoconnor1008@hotmail.com...Oh how how a repop dash cap? thanks
elvisp is offline   Reply With Quote
Old 10-23-2012, 10:02 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: How to change a 86 silverado odometer?
the ajustment for the pointer is a screw on the steering coloum
loosen and the needle will move,it has to be removed to get cluster out
http://67-72chevytrucks.com/vboard/s...d.php?t=421767
some pics may help,when i did my 78.....consider painting the inside ! worth it
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-24-2012, 09:11 PM   #3
cjlinkster
cjlinkster's Avatar
Be sure the check out your state laws. Some states do not lawfully allow the replacement of odometers.
Other than that, just pulled the dash cluster and remove the metal clip on the back of the odometer. Then insert the replacement odometer, install the metal clip, and reinstall the cluster cover.
1984 C20, 454, 4 speed named "Gold Member"
cjlinkster is offline   Reply With Quote
Old 10-25-2012, 12:02 AM   #4
elvisp
cjlinkster and motornut thank you for your reply related to my odometer change/replacement. my most concern was not to disable my working selector drive/neutral/reverse lever.motornut i think u stated that u may have another pic? but with your and cjlinkster advice i feel il be just fine. thanks guys . OHHH any place where i can purchase a dash CAP for my ride? 86 silverado?
