Old 10-21-2012, 11:18 PM   #1
buck nasty
How to clean rear power window switch
buck nasty is offline   Reply With Quote
Old 10-21-2012, 11:19 PM   #2
buck nasty
Re: How to clean rear power window switch
Old 10-21-2012, 11:22 PM   #3
buck nasty
Originally Posted by buck nasty View Post
Press plastic tabs in
Old 10-21-2012, 11:36 PM   #4
buck nasty
I used snap ring pliers to spread black plastic pce to remove contacts
Old 10-21-2012, 11:47 PM   #5
buck nasty
Dirty contacts
Old 10-21-2012, 11:59 PM   #6
buck nasty
Old 10-22-2012, 12:09 AM   #7
buck nasty
I used a wire brush to clean the 6 copper contacts and square copper pce. Use dielectric grease after on copper pse's. I also stretch the springs out a little.
Old 10-22-2012, 12:16 AM   #8
buck nasty
Put back in reverse order
Old 10-22-2012, 12:31 AM   #9
buck nasty
This spring returns the up and down switch back to center after pressing up or down. If the switch returns on it's own in the center you don't have to take the beezel off or the switch off. You can remove just the contacts and clean them.
Old 10-22-2012, 12:40 AM   #10
buck nasty
I took this picture at the start to know how the prongs faced to put it back together.Two prongs on top ,the one in center on bottom.
Old 10-22-2012, 12:58 AM   #11
buck nasty
I am sorry for the pictures being out of order. This picture should have been second after removing the bezel . Grab the switch with your fingers and twist thumbs out and index fingers up. It should pop loose. If your up and down switch returns to center, after you push up or down you don't have to do this step or remove the bezel in the first photo.
Old 10-22-2012, 10:55 AM   #12
jmack91z28
jmack91z28's Avatar
Nice, glad you did this. My rear heat/ A/C switches aren't working and are identical to your rear window switch.
This ought to come in handy.
jmack91z28 is offline   Reply With Quote
press tabs in
