10-22-2012, 12:49 AM | #1 |
Sway Bar
What front sway bar are you running? I'm looking at the one from Early Classics. Any feedback?
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
10-22-2012, 01:40 AM | #2 |
70+ ( Old Skool Club )
Re: Sway Bar
Anything from Early Classics is top notch. With that being said you can save some money by going to a wrecking yard and pulling a front sway bar off any 1973-1987 Chevy or GMC pickup or 1973 to 1991 Suburban usually for around 25/50 bucks. You can use one from a 1500/2500/3500 as the heavier trucks had thicker bars with the max thickness I believe was 1 and 1/4 inches. I have a 1 and 1/4 inch sway bar on my truck, from a 70's 9000lb. Camper Special Chevy, with Early Classics brackets for lowered trucks and installing a front sway bar is super bang for the buck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 10-22-2012 at 02:50 PM. |
10-22-2012, 02:45 PM | #3 |
Re: Sway Bar
Junk Yard bar for me. Pulled if off a 76 3/4 ton camper special. 1 1/4'' for $25. Also used ECE lowered brackets and new bushings and straps. Im into it for may be $80.
10-22-2012, 10:22 PM | #4 |
Re: Sway Bar
Thanks guys. All great options.
