will 37s fit on a 4 inch lift?
well the plan is if I buy this blazer it to do a 4 inch lift and try to use 37s. i dont wanna have to cut anything bit if I have to I would cut the front fenders but I wony cut the back. will they work?
lift= http://www.roughcountry.com/chevy_69-72_4.html tires= http://www.militaryoffroadtires.net/...t-37125165.htm
Corey Jones Designs CoreyJonesDesigns on instagram Ole Silver- 1967 stepside http://www.hotrod.com/articles/1103c...chevrolet-c10/ http://67-72chevytrucks.com/vboard/s...d.php?t=598758 |
Re: will 37s fit on a 4 inch lift?
with these beig used tires I guess they would really be like 36.5s.
I have another question with a 4 inch lift do I have to do anything with the driveshaft or will the stock one work?
Corey Jones Designs CoreyJonesDesigns on instagram Ole Silver- 1967 stepside http://www.hotrod.com/articles/1103c...chevrolet-c10/ http://67-72chevytrucks.com/vboard/s...d.php?t=598758 Last edited by jus2qwk; 10-22-2012 at 10:19 AM. |
Nope, needs to be 6" lift at least. I've got 5" lift, with some fender trimming & 36s & they occassionally rub. But good thing about the military 37s is they don't have big lugs sticking out the sidewall that can catch a fender as easily when turning.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
I could get 33"ers too rub while offroad twisten down the path on a 4"lift & 3"body so...gotta cut or go up...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
I run 33's with no lift and it's fine on and off road. I've never once experienced a rub even when articulated. 37's really don't sound that much bigger. Only 2" height difference at the tire when you figure the circumference. So in theory a 4" lift would be more than enough in my case if I wanted 37's. Albiet that doesn't take into account a really wide tire, which will make a difference.
#6 | ||
![]() Stock springs behave alot differnt than aftermarket. I gurentee if you try to follow me you will rub ![]() ![]() ![]() ![]()
I suppose if you stay on pavemnt for the most part you won't rub but it will be close...
The front of your rear wheel well and the back of your front wheel well will be the spots to watch out for... Good Luck and post pics ![]() ![]()
Like I said before I would cut the front if its an issue because new fender are so cheap but the rear I really would wanna keep factory.. just incase I decide to sell it later on down the road. and looking at some of the trails you go down I dont think I will be doing anything that crazy. just some fire roads with some mud holes
You will rub on turns. I have 37s with a 6 inch lift and it rubs.
