Old 10-22-2012, 10:36 AM   #1
ScottH
ScottH's Avatar
Can I do a 2/3" drop and use stock shocks, etc?
Thinking about putting a slight drop on my shop truck. I would put 2" springs in the front and 3" in the back. Would like to use stock shocks and panhard bar as I have new ones already.
Can anyone tell me if I can stay all stock other than the springs?
Would I need rear shock relocators or would stock position be ok with only 3" drop?
Any info is appreciated.
Scott
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 10-22-2012, 10:41 AM   #2
Dano69c10
Dano69c10's Avatar
Re: Can I do a 2/3" drop and use stock shocks, etc?
I did that drop by using CPP relocators for the back and a CPP front shock relocator on the front, the type that that relocates the mount to the top of the frame.
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 10-22-2012, 10:44 AM   #3
kyle fitz
kyle fitz's Avatar
I went with that drop with out any problems, even with stock track arm. But I used spindles in the front (highly recommended) springs in the front will be fine still. Get it aligned afterwords. It's 4 or more in the rear and 3 in the front that you'll need to relocate shocks
kyle fitz is offline   Reply With Quote
Old 10-22-2012, 03:49 PM   #4
low&slow
I'm actually wanting to do the same thing. I was looking at DJM parts lastnight. www.gcustoms.com And the site sells just the springs for a 2/3 drop and tells you everything else you will need if you decide to go lower and what you could also get for best ride quality with a 2/3 drop.
But as far as I'm concerned, a 2/3 drop will be fine with everything else stock.
low&slow is offline   Reply With Quote
Old 10-22-2012, 04:18 PM   #5
ScottH
ScottH's Avatar
thanks guys, appreciate the info
Old 10-22-2012, 09:05 PM   #6
kaycee
kaycee's Avatar
I dropped mine last winter and kept the stock shocks and have had no issues,do a search here and you can find a simple way to relocate them yourself.I am going to do it this winter you use your existing mounts just have to modify them a little.Heres the link
http://67-72chevytrucks.com/vboard/s...d.php?t=359399
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
