Old 10-22-2012, 11:08 AM   #1
Midgets50
Midgets50's Avatar
mounting shocks
Hi all,
im transplanting 4x4 axles to my strait frame on my 49 my question is, is there any specific angle that shocks have to be mounted at. also i have seen it both ways but is mounting a shock going opposite directions or same direction better..ex both shocks angle off axle to rear or one forward and other backward?
Thanks for the help in advance
Midgets50 is offline   Reply With Quote
Old 10-22-2012, 12:11 PM   #2
mknittle
mknittle's Avatar
Re: mounting shocks
Vertical is best and the closer to the wheel the better.
@degrees you get
10deg. 98%
30deg. 86%
45deg. 70%
From herb Adams chassis Engineering.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 10-22-2012, 12:57 PM   #3
mr48chev
mr48chev's Avatar
Re: mounting shocks
I'd study some solid axle 4x4's and see what angle their shocks mount at. Take a look at some of the local 4x4's with fairly stock suspensions when you are out and about and see what angle their shocks sit at. I think you will come in at pretty close to vertical as Mknittle (hey I spelled that without looking) suggested though.
Old 10-22-2012, 02:45 PM   #4
Midgets50
Midgets50's Avatar
Re: mounting shocks
thanks guys, my biggest fear was that the shock mind bind when it compressed i think i will do vertical. ive seen them like that on the newer IFS 4x4
Old 10-22-2012, 03:27 PM   #5
OrrieG
OrrieG's Avatar
Re: mounting shocks
Make sure the bolts on each end are parallel if you fab mounts. I got mine a little off and the shock would not move thru the full motion of the axle, so i got to do them twice.
OrrieG is offline   Reply With Quote
