Old 10-22-2012, 01:04 PM   #1
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Question 35” tires under a stock 79’ K30 ?
I have a chance to swap for some BF Goodrich open tread ~ 12.50 X 35” tires.
Will these fit under my 79’ K30 stock height? Or I am looking at modifications?
Thanks’
JS
johnnyclack is offline   Reply With Quote
Old 10-22-2012, 01:33 PM   #2
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Re: 35” tires under a stock 79’ K30 ?
Not sure if you are talking SRW or DRW K30..., but either way you will likely rub 35s on stock suspension.
But I fit 285/75R16 tires, (33x11.5) with no modifications on stock offset wheels, I had no rubbing at all. Then I put on 315/75R16 (35x12.5) and I did get rubbing when turning and flexing the suspension over bumps. I put 4" springs upfront and now have no rubbing, even after putting 1.5" spacers up front for a wider stance (basically the same idea as putting wider offset offroad wheels on a SRW truck).
One thing you have to your advantage is that BFG tires generally run small. Those 35" will likely measure barely over than 34". If you run them on stock wheels you may be ok, but if you put them on wider offset wheels you will definitely have rubbing problems.
Here are a few pics of mine for reference
33s on stock suspension
35s with 4" springs up front
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 10-22-2012, 01:57 PM   #3
Redcap
That is a great looking dually!
Redcap is offline   Reply With Quote
Old 10-22-2012, 03:10 PM   #4
johnnyclack
Sweet looking ride, { Sorry, I do need to post pic's of my truck}
It's a SRW, red like yours.
The tires & wheels are at a friend’s salvage yard. I have not placed them on the truck yet, I asking what I might need to do first. I get the exact tire size.
thanks.
js
