Old 10-22-2012, 04:19 PM   #1
data89
Cool Side marker lights_67,68,69,70 differences?
For a long while I've thought the un-adorned marker lights were an indication of the truck year, but, now I've seen them on 67 through 70. What gives? Are the fancier marker lights an option? I thought the fancier lights were only standard on the 70? I'm talking stepside here.
data89 is offline   Reply With Quote
Old 10-22-2012, 04:27 PM   #2
terry b
terry b's Avatar
Re: Side marker lights_67,68,69,70 differences?
I think they go by trim level.
terry b is offline   Reply With Quote
Old 10-22-2012, 04:48 PM   #3
sboris
sboris's Avatar
No markers on 67. My 68 has markers but no wiring to them. Depends on Trim level or NO trim level in my case.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 10-22-2012, 08:40 PM   #4
data89
Okay, I've looked over my pictures of my '70 stepside (frame up restoration sold 2 summers ago) and in comparing it with my '69 stepside (sitting in my shop) other than the '69 has the sidemount, I can see no discernible body or grill differences. The only original difference was the fancier side markers on the '70. So, without checking the VIN, what's the visual difference?
Old 10-22-2012, 09:39 PM   #5
too much stuff
Roadtrip!
too much stuff's Avatar
67 had no markers, 68-72 had either standard markers (with no trim) or the upgrade was with the 2 trim rings usually on the cst or cheyenne models.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 10-23-2012, 12:00 AM   #6
FirstOwner69
FirstOwner69's Avatar
My 69 CST/20 came new with non-lighted, plane Jane markers. I bought it late in the model year and noticed other 69 CSTs had the deluxe markers with the stainless trim. I complained to GM, and they looked up my VIN and stated my truck was made in early Dec., 1968, a few weeks before the markers were upgraded. Based on that, I believe all markers were non-lighted without trim until sometime during tthe 69 model year. After that, the deluxe trim levels had the deluxe lighted markers and the lower trim trim levels had lighted standard markers through 1972. I never saw an orginal 68 with deluxe markers. However, many owners preferred the deluxe markers and upgraded their's.
FirstOwner69 is online now   Reply With Quote
Old 10-23-2012, 12:09 AM   #7
Mister-B
Wow, you've owned a 69 since it was new. Impressive.
I just bought a '69 Custom20, and was a bit disappointed when I turned on the lights, to find that the sidemarkers don't light up. So, are you saying they are just reflectors, and were designed to be that way?
Mister-B is offline   Reply With Quote
Old 10-23-2012, 12:43 AM   #8
FirstOwner69
Just reflectors. No light sockets. Here's a pic of the back.
Old 10-23-2012, 01:33 AM   #9
Mister-B
How strange. Thanks for the info
Old 10-23-2012, 01:47 AM   #10
SS Tim
SS Tim's Avatar
The easiest thing to do is pull the markers and look. You might see the wiring or if the lens has the socket cutout. A bright flashlight shoud reveal the bulb if there is one. remember they can be added and probably should be.
SS Tim is offline   Reply With Quote
Old 10-23-2012, 03:05 AM   #11
MacGyver72
MacGyver72's Avatar
Somewhere in this forum is a detailed explanation of markers. I'll give it a shot to explain. When GM designed the new truck the feds had no side marker requirement. When they went into production in 1967, there were no markers but legislation had already been passed declaring that all vehicles manufactured for the 1968 model year had to have reflectors. The same legislation was upgraded to require lighted side markers for the 1969 model year. GM scrambled to meet the requirements but the '68 specs were already out with no place for a fender marker. They simply cut a hole and put the reflector in which is why there seems to be an interrupted flow in the look. The reflector had to be designed and since they knew eventually they had to have a light, they molded the plastic to be easily modified for a socket. That's why the 1968 reflector looks like someone forgot to cut the hole for the light. The harness had no accomodation for a light so the reflector was molded closed. They cut the hole the following model. Then since they had this flat piece on the side of an otherwise beautiful truck, they designed one with trim to enhance the look.
MacGyver72 is offline   Reply With Quote
Old 10-23-2012, 11:05 AM   #12
data89
Interesting. My '69 original it had the plain side markers with bulb sockets, pigtails attached, (no bulbs). So all I had to do was wire them in and put bulbs in.
But, the question remains, what are the body style differences between the '69 and the '70? I had both (verified by VIN and registration) and can see no difference.
Old 10-25-2012, 06:25 PM   #13
MacGyver72
MacGyver72's Avatar
Since the bulb requirement didn't hit the law until the 69 model year, it may be that you either had an early construction (that is built in 68) that had the harness and the hardware but they were never connected. Just a guess on my part. It could also be that they simply forgot to assemble them. Again due to the early production. Line workers changing from one model to another often make little mistakes being used to the old model before they get used to a new routine.
Old 10-25-2012, 06:28 PM   #14
Mister-B
I removed one of the rear side markers on my '69 this week, and there's no bulb, no wiring, and no hint of anything besides this just being a reflector.
Old 10-25-2012, 06:33 PM   #15
MacGyver72
MacGyver72's Avatar
The law only referred to front marker requirements. GM put the rears on for continuity of design. I've never seen front lights without rear lights but unless your bed was swapped, they obviously exist. :-)
Old 10-25-2012, 08:27 PM   #16
SS Tim
SS Tim's Avatar
... Again due to the early production. Line workers changing from one model to another often make little mistakes being used to the old model before they get used to a new routine.
More likely was using up existing stock harnesses before they had to change over.
Old 10-25-2012, 09:39 PM   #17
MacGyver72
MacGyver72's Avatar
Yep. You're probably right. When I read it I thought he said the harness had the right wires but they weren't connected to the pigtail. And they definitely use up all old parts. It's called a buildout and when you have too many dead parts for not properly calculating what is needed, the execs get mad.
Old 10-25-2012, 10:17 PM   #18
FirstOwner69
According to Wikipedia, the requirement for reflectors AND lights went into effect Jan. 1, 1970. That would likely explain why some 69s such as mine had only reflectors, empty sockets and/or no wiring provisions. I know for a fact my 69 was made early Dec. 1968.
Old 10-25-2012, 10:23 PM   #19
MacGyver72
MacGyver72's Avatar
Well there you have it. Mystery solved.
Old 10-28-2012, 01:47 AM   #20
SS Tim
SS Tim's Avatar
Found it. The marker lights were an option in '69. They may have been added to specific packages but they were an option, RPO UB3and marked as a change in the Data Book MY '69 update dated April 1, 1969. Somebody had a sense of humor there!
